Old 06-04-2018, 01:38 PM   #271
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
Originally Posted by Captain Yaris View Post
I put in a call to my service advisor because it dawned on me that possibly it didn’t get wired from the factory by mistake. I’ll follow up and advise as to what I find out.
i wonder if its a thing that gets prewired with the power mirrors.
hey i found your guide
https://www.youtube.com/watch?v=vLyRH5eSpps
DarkShadowFox is offline   Reply With Quote
Old 06-15-2018, 01:50 PM   #272
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
Just an update: I was told by my service advisor that they are not willing to help, install, or sell parts pertaining to installing cruise control. Apparently they are spooked because of the past law suits that had to do with the stuck accelerators.
Captain Yaris is offline   Reply With Quote
Old 06-21-2018, 02:50 PM   #273
Captain Yaris
Got it figured out, and now it’s alive!!!!!!!!!! I had to swap a wire that was just a plug with a ground with a different wire that included the ground and connection to the cruise control unit. A special thanks to DarkShadowFox for hyperlinking that video of the Rostra install. It gave me the idea to pursue the correct wire from Toyota. Thanks for the help.
Part numbers to install on US Spec 2016 Yaris L are as follows:
Cruise Control Switch (84632-08021)
Clutch Switch; for cars with manual trans. (8820-42010)
Steering Wheel Switch Cover (45186-0D150-C0)
Cruise Switch Wire (84633-02020)
Cruise Control Switch Screws; need 2 of these. (90159-50199)
File Type: jpeg 4AB0BF84-8153-4B63-B522-72276B4A09F7.jpeg (207.3 KB, 366 views)
File Type: jpeg A52410CA-9F2A-4CF7-BB71-48548B662609.jpeg (164.6 KB, 356 views)
Old 06-21-2018, 03:10 PM   #274
DarkShadowFox
LMAO JFC dont tell me even the L gauge cluster has a spot for the cruise control omfg. they are ripping people off on these yarises lmao.
Old 06-21-2018, 03:16 PM   #275
Captain Yaris
It sure as hell does!
Old 06-21-2018, 03:22 PM   #276
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Your dealer person is crabby apparently. The dealer I bought my 2016 Yaris L from actually gave me the clutch switch and installed it for me after I showed them I plugged in the factory switch from another car into the steering wheel and that it lit up on the dash. The service adviser wanted to see if it would actually work hahaha.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 06-21-2018, 03:49 PM   #277
Captain Yaris
I remember that! That’s why I wouldn’t give up, I know it’s been done before. My dealer deals with a lot of little old ladies buying Corolla’s, Camry’s, and Rav4’s. They just sell the higher package and could care less about modding.
Old 06-21-2018, 04:33 PM   #278
DarkShadowFox
DUMMM. o well i wanted power locks and the rear lock squishy panel vs a manual lock and im not going to be the one to make a thread on how to install that. thats more money then you save on buying an L .
Old 06-21-2018, 04:50 PM   #279
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I hope CTScott is well.
On Instagram
On Wheelwell
Old 06-21-2018, 05:42 PM   #280
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Me too.
NYC-SE is online now   Reply With Quote
Old 06-21-2018, 05:48 PM   #281
Captain Yaris
Is he not ok? I haven’t seen him on here in awhile.
Old 06-21-2018, 09:29 PM   #282
He's been on, just not posting.
Old 07-12-2018, 02:17 PM   #283
irakli_86
Drives: Yaris MK2
I've just installed the cruise control stalk into my 2012 Yaris with a 1.3 (2NZ) engine. Its automatic and GCC (middle east) spec. Straight plug and play into the 4 pin connector slot which was empty next to the 10 pin connector. Mine has audio buttons as well bluetooth handset buttons. I didn't have to swap any pins whatsoever, cruise light and set all work fine.
Took about 10 minutes including setting up the audio after battery disconnect.
Only thing remaining is for the oem cover with the hole and rubber grommet to arrive.
Thanks to CTScott for all the info in this thread !
irakli_86 is offline   Reply With Quote
Old 07-28-2018, 01:52 AM   #284
Per Olof
Drives: Toyota yaris G 2014
Hello I´m new at forum,I want to now if my Toyota Yaris is ok for cruise control
the picture is from under the steering next to yellow socket,the 10 pin socket
and if I can buy a set from you Scot
Per Olof is offline   Reply With Quote
Old 08-23-2018, 03:16 AM   #285
vigvoodoo
Drives: 2016 Toyota Yaris L
Will this work for:
2016 Toyota Yaris L base model
Automatic
Touchscreen
No steering wheel controls
vigvoodoo is offline   Reply With Quote
Old 08-23-2018, 10:27 AM   #286
DarkShadowFox
scot does not sell sets he is not a dealer. you can buy all the parts from the internet. on camelback. he just assembles things.
Old 09-08-2018, 05:36 AM   #287
Per Olof
thank you for your ansver,I have look at Rostra and conection to ECM is not possible
Its a diffrent ECM behind the glove compartment,But I found a good universal one at
CANM8 England,It works fine in my car from OBD and can bus,the only thing is that it
dont get brake signal to can bus, but they send me extra conection from the brake padel to cruise module,I have test it already and it works fine without extra adjustment,it has a cruise brake butten on the backside of the stulk
Old 09-19-2018, 09:35 AM   #288
milhouse
Drives: Yaris 2012 1.0 5 doors
Dear Friends!
Tell me known yaris 5 doors hatchback 2012 with 1.0 european version spain
KSP90L-CHMRKW
can be to installed CCS ?
Thanks a lot!
milhouse is offline   Reply With Quote
Tags
cruise control. 2012
