![]() Drives: 2006 Yaris 3-Door Manual Join Date: Oct 2014
2006 Throttle Body Swap
I'm looking to do the Corolla TB swap and car knowledge is sorta limited (still learning) I'm wondering exactly what I should be looking for (year, donor engine, part #, ext) if I'm gonna try and source one from a Pick N Pull.
I'm putting it on a 2006 3dr Yaris CE. Also is there and important steps I need to take or is it just direct bolt on? Also any suggestions on which spacer would be best? https://www.ebay.ca/itm/SILVER-THROT...8AAOSwdcZa5TWc https://www.ebay.ca/itm/BLUE-Throttl...wAAOSwCFta-hGK |
What are you trying to achieve with a TB swap?
Sent from my SM-G930W8 using Tapatalk |
looks like 4 bolt DBW. any 1.8 1zz will work. it's easy. hardest part is cold idle tune screw coating removal.
feed my pet
I prefer this TB spacer design over the rest:
Photo 15-12-2016, 23 16 59.jpg It's like a funnel into the TB. |
#5 | ||
#6 | |
![]() ![]() Drives: Yaris 07 HB Join Date: Apr 2011
feed my pet
message them over fb:
https://www.facebook.com/KC-TBS-Inte...6710809418301/ |
| Tags |
| body, corolla, swap, throttle |
| TPS reading at WOT with 1ZZ throttle body? | 4/20 NEVER FORGET | Performance Modifications | 14 | 07-02-2023 05:20 AM |
| 1.8L throttle body dimensions drawing | CrankyOldMan | DIY / Maintenance / Service | 5 | 03-09-2016 10:30 PM |
| throttle body | jtoxx | DIY / Maintenance / Service | 0 | 02-17-2016 09:35 PM |
| Intake for the 1ZZ throttle body? | fuji | Performance Modifications | 9 | 06-14-2009 01:02 AM |
| 1zzfe throttle body | lilman717 | Performance Modifications | 22 | 02-12-2009 08:08 PM |
