![]() ![]() Drives: 2012 Toyota Yaris 1.3 -3rd Gen Join Date: Aug 2017
Engine tuning
I recently enquired with a reputable engine management tuning company as to see if there is anything they can do. They have a software which is dyno tested before and afterwards for proof on the yaris and is very moderate in terms of power gains.
I have heard our yaris ecu's don't like to be tuned and can cause issues. Has anyone else had a problem with any tuning of there systems? Sent from my SM-N910F using Tapatalk |
#2 | |
uh whats the name of the tuning company and where are they based out of. |
The general consensus seems to be that using a piggyback or replacing the ECU is the way to go.
Even then piggybacks have been reported to essentially lose their tune as the stock ecu sometimes "relearns" itself. This has been well documented on corolla forums. The first gen Yaris' (echo's) don't have an afr sensor and piggybacks work fine on those which makes going turbo much easier from what I have read and discussed with people
If your country allows standalone ecu's and it keeps it road legal then go with a standalone ecu that your local and trusted tuner if familiar with. This will make it much easier to tune the engine the way you want
#7 | |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 12:56 PM |
| Check engine light + vibration | Lisbeth | DIY / Maintenance / Service | 12 | 04-05-2020 10:28 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 04:07 PM |
| Engine Delayed Start - Toyota 1NZ-FE 1.5L | SL Runner | General Yaris / Vitz Discussion | 9 | 07-23-2011 04:13 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
