Iridium spark plug - longer thread
Hi guys,
so far I have been using "normal" NGK BKR5EYA but I wanted to try some Iridium plugs. Local store recommended me Denso IKH16TT. Now I am comparing them against each other and the Denso has considerably longer thread part... the rest ("above the nut") seems identical. Check the picture... I must say I did not have the balls to put the longer plug in. Any experience with it please? Do I need to ask Denso directly to be 100 per cent sure? My Yaris 2007 uses 2SZFE engine - 1.3 with 64kW. Thank you!
Don't put that in, its the wrong plug.
I like to go to rockauto site just to search part numbers, you could check that out there.
![]() Drives: 2007 Yaris hatchback Join Date: Mar 2018
That’s definitely not right. Don’t damage your engine with that. It looks like that goes in a truck engine. You need IK16TT. That’s what I put in mine and they’re good plugs.
Yep, the store already confirmed the mistake on their end and they will change the plugs for IK16TT. Thanks for your quick response guys.
| Spark plugs suggestion | walt101786 | DIY / Maintenance / Service | 29 | 03-05-2023 09:06 PM |
| NGK 5464 Iridium IX vs NGK 4996 Laser Iridium Spark Plugs | Cigar_Maverick | DIY / Maintenance / Service | 8 | 05-21-2016 04:07 PM |
| Iridium spark plugs? | Septembersrain | Third Gen Yaris General Discussion | 4 | 07-02-2014 10:56 AM |
| bit of spark plug insulation may have fallen into cylinder | alagappan the proud | DIY / Maintenance / Service | 20 | 01-09-2014 06:10 PM |
| bought iridium spark plugs but need help | Shinare | DIY / Maintenance / Service | 24 | 08-05-2013 12:21 AM |
