Old 09-05-2018, 05:12 PM   #1
Jedurso
Drives: 2010
Unhappy Strong vibration on highway..... help
Hi all. 2010 yaris. 105 thousand miles. 500 miles highway weekly.
So, I have a strong vibration and pulling to the right. Most notiable on highway. Took for an alignment, didn't help. Took back 3 days later, realignment, didn't help. Say it's suspension.... okay. Tire rods are fine, control arms are fine. Where am I looking????? I have new spark plugs, coil packs, fuel injectors, and belt. Also took off and cleaned my throttle body and rear breaks are a month old. I do need tires.... can it be that simple?. Please help, this is my only vehicle and it has to last.
Jedurso is offline   Reply With Quote
Old 09-05-2018, 11:41 PM   #2
fan_aLba
Drives: 2008 Yaris s
Try rotating tires around, check tire balance, you can have them put the car in the air and with the car on accelerate spinning the tires to a speed to see if the what wheel is shacking vibrating
fan_aLba is offline   Reply With Quote
Old 09-06-2018, 03:23 PM   #3
bronsin
bronsin's Avatar
You overlooked the tires. Check for dammage. Balance check. Good luck!
Old 09-06-2018, 04:35 PM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes it can. If you've had an alignment and checked the suspension as you say then that's what we have left. I would have started there first.
NYC-SE is online now   Reply With Quote
Old 09-06-2018, 05:36 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Get some new rubber.
Old 09-07-2018, 05:07 PM   #6
Jedurso
Drives: 2010
Thanks everyone, ordering a set now. I'll update when I have them
Old 09-07-2018, 05:11 PM   #7
Jedurso
Drives: 2010
And the only reason I didn't go there first is because I still have some meat on them and this came on kinda sudden. Not night and day sudden, but progressive over two weeks or so.
Old 09-07-2018, 06:11 PM   #8
kimona
kimona's Avatar
You can find great deals here:
https://www.discounttiredirect.com/f...size/185-60-15
Excessive vibration over 60mph. Suspension related? Aclosefriend Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-29-2016 06:06 PM
Need some advice on intermittent vibration coheed DIY / Maintenance / Service 5 04-20-2015 11:54 AM
Pulsating Vibration dbudworth General Yaris / Vitz Discussion 5 03-28-2011 04:06 PM
Strong vibration when accelerating... why peposhi General Yaris / Vitz Discussion 8 02-25-2010 08:29 PM
Vibration or shake at highway speed? evan DIY / Maintenance / Service 10 11-10-2008 09:23 AM
