![]() Drives: Toyota Yaris 2008 Join Date: Apr 2011
Center Console Lid Pops Up!
HELP!!! my center console lid keeps popping up at any time and for no apparent reason!! it´s REALLY annoying and may even cause an accident since my 2008 Yaris Sedan is standard transmission! How can I fix this? apparently there´s nothing wrong, the tab that locks, is not broken so I guess the console itself moved :( is there a way to disable the spring mechanism that pushes the lid upward? or any other way to fix this? THANKS!
More details:apparently the spring mechanism that pushes the lid up, also pushes the lid outward when closed unlocking and opening the console. Any help? Last edited by Rigojr; 08-10-2012 at 06:19 PM. Reason: more details of problem |
I GOT IT! All you need to do is pup off the cup holder, loosen the 2 screws, pull the rear part of the console which comes attached with clips and then tighten the two screws in the middle that support the spring mechanism. This procedure can be done in less than 10 minutes!!!
![]() Drives: 2008 yaris Join Date: Mar 2015
THNKS!!!
I have the same problem - will report back if fix works for me!
HOORAYYYYY!!!
My sincere thanks to you for posting this fix, your directions worked beautifully and my center council is now fixed.
(Side note: when I took it to the dealership they said a new one would be like $600 but to try pick-n-pull for a replacement that they'd be happy to install for another $50)
Glad to be of some help
Glad to be of some help! :)
![]() Drives: 2007 Toyota Yaris Sedan BASE Join Date: Oct 2018
I know this is from 2012 but I'm having the same problem right now. Console won't stay closed. Does anyone have pics on a how to do this? Or can someone clarify the written instructions?
feed my pet
There’s a video but you might not understand what he is saying
https://www.facebook.com/10000918197...9941110988600/ remove cup holder and tighten the 4 screws Sent from my iPhone using Tapatalk |
#8 | |
#9 | |
![]() Drives: 2009 Toyota Belta 1.3L CVT Join Date: Nov 2021
I appreciate your help Love from Saint Lucia |
| Advice needed on maintenance and cosmetic repairs | md3k | DIY / Maintenance / Service | 12 | 08-07-2012 02:30 PM |
| Interior: Pics of center console removed? | schleppy | Cosmetic Modifications (Exterior/Interior) | 23 | 12-09-2010 01:45 AM |
| Center Console Trim Pieces + Vent Register | bradfucious | Willing to Buy by private party | 16 | 05-07-2009 01:51 PM |
| Clicking noise in center console? | devinlamothe | General Yaris / Vitz Discussion | 8 | 09-16-2006 12:03 PM |
