#289 |
![]() Drives: 2007 Yaris Join Date: Jun 2018
Hi everyone,
I have a US Model, 07, M/T, 1.5L, 3 door hatch. I'm installing this CC solution and I'm at the point where I'm running the D3 connector to the ECM pin 40. Please see the pic below. Which wire and pin do I send to the ECM and which one do I ground? The picture of my Yaris is different then the pictures in the instructions from CTScott. Thanks!! https://share.icloud.com/photos/04lH...ah7sf_DqrWtH0A |
#290 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
#291 |
![]() Drives: KSP130 Join Date: Sep 2018
#292 |
![]() Drives: Yaris 1.3 europe Join Date: Oct 2018
Hi
I have yaris 2013 1nr-fe 1.33 engine europe specs and installed the cruise stalk . The problem is the indicator at the instrument cluster doesn't lit .Otherwise the cruise control works just fine . Is it possible to fix this problem ? |
#293 | |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
If its the basic one without RPM meter it probably also dont have the cruise light. Then you can switch it to one of these which should have cruise lights, my car has it. https://www.ebay.de/itm/Toyota-Yaris...p809:rk:2:pf:0 https://www.ebay.de/itm/Toyota-Yaris...UTE:rk:36:pf:0 https://www.ebay.de/itm/Tacho-Kombii...MAAOSwyWlbpqhd
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 Last edited by stykerdk; 12-05-2018 at 03:03 PM. |
#294 | |
I have the one with the RPM meter and i am sure that it has the cruise light because i can see it with a flashlight but for some reason the light don't lit . Maybe it's something that need to be unlocked through toyota diagnostic computer or something else that i don't know . |
#295 |
Dear Experts
Please help to confirm if ECM # 89661-5C340 (Japnese spec, 1.0L engine i.e. 1KR-FE) support cruise control? |
#296 |
![]() Drives: Yaris Active 2018 Join Date: Mar 2019
Ciao, have Active Yaris 2018. I can't open for install Cruise control. Can you help me. Thanks
Inviato dal mio ONEPLUS A5010 utilizzando Tapatalk |
#297 | |
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
#298 |
![]() Drives: 2019 Yaris HSD Join Date: Jun 2019
Came here through Google. Got a brand new 2019 Yaris Hybrid (EU model), given to me by my employer (it's a 4 years lease). First off, I'm really impressed with the build quality and level of equipment for a base model. I do a lot of highway driving, so cruise control is a must for me. I bought a "cheap" stalk on eBay, received it on Friday and yesterday I installed it. Unclipping the airbag was a PITA, but finally I got into the steering wheel. Installed the stalk and drove off to test it. Everything works great. The 2019 steering wheel is again different, so the usual covers sold out there, don't match. Ordered the correct one from Toyota. It was 5€ and delivered in one day. Part code is: 45186-0D030-C2
Few Photos... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#299 |
![]() Drives: 2010 Toyota Yaris 5dr Join Date: Jan 2011
Been thru this twice. If I have to plug in the cruise wires in the steering wheel connector which and what colors ? I have a 2017 Yaris L
#300 |
![]() Drives: Hatchback Join Date: Jun 2019
DIY Cruise Control for 2012 Yaris - Good News!
IMG_0246.jpg Here is a picture of the cruise control connector to the steering for a (US) 2017 L base Hatchback with volume controls (empty slot on right). There is only one way to connect the clip.
Sent from my iPhone using Tapatalk |
#301 |
![]() Drives: Vitz 2011 with 1NR-FE engine Join Date: Aug 2019
Plz help whether 1NR-FE 1.33 dual vvti CVT with ECU # 89661-52Q90 has built in cruise and ASL function?
And ECU pin out required? Or pin number for CCS and ASL for spiral cable installation. Thanks Umarzafar88@gmail.com ![]() Sent from my LYA-L09 using Tapatalk |
#302 |
Drives: Yairs 2015 hybrid Join Date: Feb 2022
Yaris hybrid 2015 CC install
Can I install CC on my 2015 Yaris hybrid? Has anyone tried? Can anyone tell me if it will work? Thanks
#303 |
Drives: Toyota Yaris 2012 Join Date: Jan 2023
Hi CTScott, I know this post is now 10 years old, but I am looking to install a CC stalk on my 2012 Toyota Yaris and am wondering if by any chance you are still selling the side steering wheel covers (with cutout for CC stalk) for $5? I am in the US. Thanks
#304 |
![]() Drives: Toyota Yaris NPL130L Join Date: Jul 2023
Hi,
May someone help me, already sent a post, and had some help, but Am stuck. ( Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > DIY / Maintenance / Service 2014 Yaris Cruise Control - No Success ) I have this Yaris: NLP130L-CHFNXW (2014 European Model MT) ENGINE: 1NDTV 1400cc Diesel turbo Can someone tell confirm the CC will not work on Yaris Diesel Models? Thanks Kind regards |
#305 |
![]() Drives: xp130 d4d Join Date: Jan 2021
same here, no luck. from what i ve researched you will also need to route pin cables through the wheel to the ecu
#306 |
![]() Drives: Toyota Yaris 3 100 VVT-i 2015 Join Date: Oct 2025
GIVING ADVICE TO AVOID A STUPID MISTAKE I MADE on my Toyota Yaris III (100 VVT-i Collection 5p, 2010–2015)
I spent a lot of time browsing forums to get the cruise control stalk to work on my car (the clutch switch and CC light on the instrument cluster were already in place). The reason it wasn’t working was that I had wired it incorrectly in the steering wheel. At first, I plugged the stalk into the brown cable connector—it fit, but it was a bit smaller. Instead, I should have connected it where all the steering wheel cables meet (blue, brown, and yellow connectors). There was an empty slot there that perfectly matched the stalk connector. For other Yaris models, you might need to install additional parts. Here’s a great step-by-step DIY guide: https://www.toyotanation.com/attachm...iy-pdf.419080/ |
| Tags |
| cruise control. 2012 |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 12:59 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
