![]() ![]() Drives: 2012 Toyota Yaris 1.3 -3rd Gen Join Date: Aug 2017
Help needed.
Could anyone with a factory head unit and reverse camera please help me. If you remove the plastic cover on the inside of the tailgate it will expose the camera position and cable. I took mine off and there is a open connector by the camera and I need to confirm if the camera is for that connection as it may be pre wired In to the 2013 Yaris. I have attached what it looks like. If you can could you also please see the code/part number on the camera and reply with it aswell.
![]() Sent from my SM-A530F using Tapatalk |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I think you will find that connector is for the central locking if the car has a key lock in the back door.
Most likely a black wire and a blue wire. Grounding the black wire will lock the doors, and grounding the blue wire will unlock them.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
Take a look Here there is Good pics of the inside tailgate with reverse camera.
https://www.ebay.co.uk/itm/Toyota-Ya...QAAOSwEKxcWwOF I Think you need this wiring loom. https://www.ebay.co.uk/itm/TOYOTA-YA...4383.l4275.c20
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 Last edited by stykerdk; 02-06-2019 at 03:44 PM. |
#4 | |
#5 | |
I almost forgot toyotatech is your friend.
https://www.toyota-tech.eu/Aim/Aim2....AIM&menuitem=2 Looks like you need to buy a cable for the whole way from rear to head unit. https://www.toyota-tech.eu/aimupload..._003_187_1.pdf
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
#7 | |
Here and they ship worldwide.
https://sunparts24.de/en/PZ457B014000
| Tools needed for MTM fifth gear R&R? | 2009Toyotoad | DIY / Maintenance / Service | 5 | 06-21-2015 05:51 AM |
| Tail light LED replacement: mod needed? | Yarflana | DIY / Maintenance / Service | 3 | 02-26-2013 10:46 PM |
| cost effective sensible mods help needed | macguyver | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-01-2012 10:21 AM |
| What is needed for coilovers | justinparadise21 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 01-03-2009 12:53 AM |
