#37 |
2ZR swap. DO IT! Ask how!
I bought it for curiosity as well as for insurance. I wasn't able to get in on the RPM long tube header before it went out of production and I'd rather not get stung that way again. You can buy just the manifold directly from TKC if you don't want to go for a full kit. They also offer packages with the manifold, down tube and your choice of turbo. Granted that's designed for the Corolla/Matrix/Vibe platform so the down tube might not be usable as is. I figure that the whole thing will need to be custom built and the manifold is the only pre-fab part I can use for sure.
#38 | |
Lay the oil to the Yaris and you'll never have to deal with rust. I can tell you all the spots to hit. In fact, I just had my '08 up on the hoist today and gave it another blast of Proform.
#39 |
![]() ![]() ![]() Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
Cool. I wish I had access to a hoist. I have to do everything on stands.
Sent from my moto e5 play using Tapatalk |
#40 | |
With regard to the turbo, Danny at JD Racing strongly recommends against the AEM FIC in favour of a standalone due to issues with FIC tuning. He says that fuel trims cannot be manipulated in any meaningful way and that the FIC and car's ECU will constantly fighting eachother. I was surprised by this as I've read about successful prepacked turbo kit installs from MWR and tubrokits.com.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 02-03-2019 at 07:39 AM. |
#41 | |
3 Yaris and counting..
#42 | |
Holy crap, they're discontinuing a LOT of those connectors. I should probably get off my ass and buy one before they're gone! |
#43 | |
#44 |
![]() ![]() Drives: 05 Echo Join Date: Jul 2009
If you want to run MS and maintain the VVT it's not cheap, I think you'll need MS3 pro.
I'm going to ditch the VVT and use Microsquirt V2.2 on the Echo. I was just thinking of posting a wanted ad for a stock computer for the case and connector Last edited by suprf1y; 01-28-2019 at 12:47 PM. |
#45 | |
As far as the connector goes, you can get one online for less than US$15. https://www.mouser.com/ProductDetail...w7vTC0RkzXE%3d |
#46 | |
I agree with you that a kit for this configuration (2ZR in Yaris) is probably going to have to be mostly custom and therefore likely very expensive. Also, as far as electronic management of the system, from what I've been reading, the AEM FIC - which is more affordable - is less than ideal when compared to a standalone ecu. That alone could add close to $1000.00 to a project. I see that a member here has a Camcon for sale and apparently it can adjust fuel and timing, but I think I read that it only works for VVTi, not Dual VVTi. Do you know anything about the Camcon?
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 02-03-2019 at 07:38 AM. |
#47 | |||
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| 3rd gen engine swap, 2ZR? 2AR? Swap newbie | m.flores.0928 | Third Gen Yaris General Discussion | 6 | 10-02-2020 10:54 AM |
| 06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 08:12 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| 1zz swap...is it worth it??? | jouna | Performance Modifications | 12 | 11-10-2009 09:33 PM |
