![]() Drives: 2007 Hatch Join Date: Feb 2019
2007 hatch front passenger ball joint
Back in 2015 I replaced the front passenger lower control arm for my brother in law on the yaris I now own. It was a bear to get the front LCA bolt out to swap it. Is it possible to replace just the ball joint? I went to get an alignment and that ball joint is shot so they won't do the alignment. I see moog makes a ball joint (pn k500118). Just curious if anyone has successfully replaced just the ball joint.
I haven't on any Yaris, but have on other imports. You'll need a ball joint press & a snap ring plier. It's too bad Toyota didn't use the bolt on ball joints on the Yaris like it's other cars.
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Anyone ever notice how similar (pretty well exact copy) the yaris front end is to a mk2 or 3 vw? They use bolt in ball joints though. Makes for a change anyone can do with basic tools.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
#4 | |
Sent from my CLT-L04 using Tapatalk |
#5 | |
![]() It doesn't appear to be being used properly in this pic but you can see the idea
| 2007 Yaris hatch - thinking TRD | Type-Y | General Yaris / Vitz Discussion | 18 | 01-18-2018 10:47 PM |
| Ball Joint Replacement? | zoidberg444 | DIY / Maintenance / Service | 4 | 05-03-2017 08:55 AM |
| URGENT. BALL JOINT REINSTALLATION QUESTION | xb visitor | DIY / Maintenance / Service | 4 | 05-09-2014 06:02 AM |
| Front Lower Ball Joint Cotter Pin Replacment | GrayYaris | DIY / Maintenance / Service | 5 | 04-25-2014 04:30 PM |
| Ball Joint on Bottom Arm | David Godfrey | DIY / Maintenance / Service | 1 | 04-18-2010 06:27 PM |
