Old 04-28-2019, 01:29 PM   #1
Bony_ahmed
Drives: Toyota Yaris SEdan
parking brake light on & abs light on ! car stuck in 2nd gear !!!
mine is an Automatic 2007 yaris, today i was driving home....suddenly the parking brake light & abs light came on, and transmission is not shifting gears, its stuck on 2nd gear. I've checked.....all the fuses, they are fine......what could be the reason
Bony_ahmed is offline   Reply With Quote
Old 04-28-2019, 06:02 PM   #2
ex-x-fire
You need to get codes read.
Old 04-29-2019, 01:56 AM   #3
Bony_ahmed
I don't have a professional scanner......can you help me with how to read codes without scanner
Old 04-29-2019, 07:57 AM   #4
rayfloyd170
Drives: Yaris 2016 1.3 Manual
you cannot read codes without an OBD scanner/reader. you need to buy it, very cheap from aliexpress or any from your local auto store. if you dont want to buy then you may borrow from your friends if they have..
just pair it with your phone then you need to run some aps like torque or other apps that can scan and read error codes and the error code/s will pop up for you to make a start of your diagnosis.
rayfloyd170 is offline   Reply With Quote
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 03:59 PM
ABS BRAKE light FIX sedan IndestructibleYaris DIY / Maintenance / Service 4 11-27-2021 02:35 PM
My Car Shakes Noticebly when I Put The Gear into Reverse When The Car Is on a Slope Meteorite2 DIY / Maintenance / Service 3 11-14-2014 06:56 AM
Car got stuck in gear? mr_miles DIY / Maintenance / Service 1 03-24-2012 12:25 PM
ABS LIGHT & E BRAKE LIGHT rossman DIY / Maintenance / Service 5 02-26-2010 12:09 AM
