Old 06-29-2018, 01:44 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
sparco
Made a trip down to their location in Irvine, CA, yesterday. Picked up a few things I need for my next mod and snapped a few pics of the facility.
I'll update this thread with the progress.
On Instagram
On Wheelwell
Old 07-01-2018, 12:17 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
That must have been fun! Looking forward to your updates.
Old 07-01-2018, 10:25 PM   #3
Driver of the seat in the last picture must have had a lot of Taco Bell. ROTFLMAO
Old 07-02-2018, 12:14 PM   #4
ern-diz
ern-diz's Avatar
It was pretty cool, yes. If all goes as planned, I should have a couple updates over the next week...
On Instagram
On Wheelwell
Old 07-09-2018, 03:47 PM   #5
ern-diz
ern-diz's Avatar
The final result below!
Only issue I ran into is a flashing passenger seat belt light. We relocated the factory seat belt buckles and respective wiring to the sparco seats and reconnected the wire harnesses, with the exception of the air bag modules (obviously). We expected to see the amber 'airbag off' light to the right of the AC vent, as well as the red airbag light on the dash cluster itself. What we didn't expect to see is a red flashing passenger seat belt light on the same panel to the right of the AC vent where the airbag on/off lights are.
The passenger seat belt buckle had two wire harnesses for what we believed to be the seat belt and airbag. The driver seat had a third harness (no idea what for). Both seat belts buckle and there is no beeping. Unbuckling the driver seat belt produces a red seat belt light on the dash cluster, as normal. Buckling the driver seat belt makes that light go away, so I'm sure the flashing seat belt light on the right side in the air bag on/off light area is related to the passenger seat belt. Buckling the passenger seat belt doesn't make the light disappear. We tested coming to a hard stop and both seat belts still lock-up under hard braking. Everything appears to be normal, so I can't understand why the blinking passenger seat belt light appeared. The only thing we didn't reconnect on the passenger seat was the airbag wire harness.
I'm searching the forum/internet for answers but if anyone knows what we did wrong, I would greatly appreciate the guidance.
On Instagram
On Wheelwell
Old 07-11-2018, 12:04 AM   #6
Type-Y
Drives: 2007 Yaris hatch
Those seats look great in the yaris. Probably a bit more comfortable than stock, I'm guessing
I think the passenger light has something to do with the sensor in the oem seat that detects the weight of when someone is sitting there and maybe the lack of that sensor is causing the light...
Type-Y is offline   Reply With Quote
Old 07-11-2018, 12:12 PM   #7
ern-diz
ern-diz's Avatar
It's funny because as a bigger dude, the bottom part of the factory seats might have been a little more comfortable. The sparco's are more narrow so the bolstering on them bite into my hips a bit more. However, everything else about them is far more comfortable. The back support is better, they sit lower in the car so my door and center arm rests have become more comfortable, I feel like I gained an inch or two of leg room and I'm able to bring the steering wheel all the way down to it's lowest position without bumping my right knee against it when braking. If it wasn't for the bottom part of the sparco's being a little more narrow and their bolstering biting into my hips a bit, they'd be more comfortable in every way. In the end, it's still comfortable and with all the other gains, I'm super happy with them.
As for the sensor, that's what it sounds like my problem is.
On Instagram
On Wheelwell
Old 07-11-2018, 11:15 PM   #8
Type-Y
It's funny because as a bigger dude, the bottom part of the factory seats, might have been a little more comfortable. The sparco's are more narrow so the bolstering on them bite into my hips a bit more. However, everything else about them is far more comfortable. The back support is better, they sit lower in the car so my door and center arm rests have become more comfortable, I feel like I gained an inch or two of leg room and I'm able to bring the steering wheel all the way down to it's lowest position without bumping my right knee against it when braking. If it wasn't for the bottom part of the sparco's being a little more narrow and their bolstering biting into my hips a bit, they'd be more comfortable in every way. In the end, it's still comfortable and with all the other gains, I'm super happy with them.
I have a feeling the padding will adjust to you over time and they’ll be a better fit. One thing I don’t like about most OEM seats is they’re usually not deep enough, those look nice and deep.
Old 06-07-2019, 09:33 PM   #9
heeroyuy01195
Post count means nothing.
I don't mean to be a thread necromancer here, but have a few questions. Looking into some Recaros for my hatch but was curious about the height drop. I'm about 5'5" (we Asians are short haha), is the height difference drastic enough to impact visibility between the stock seats and the sparcos? My plan is wedge brackets with their sliders and Recaro Speed seats. Other thing, how easy is it to get into the back seat?
Old 06-10-2019, 12:14 PM   #10
ern-diz
ern-diz's Avatar
In terms of seating position, I definitely went down a couple inches. Can't say exactly how much, but my door and center armrests feel like they work better now because I'm lower, so they support me a bit more. Not enough to have changed my view of the windshield, though. It's really only a couple inches and only noticeable when placing your arms on the rests.
Getting into the back seat is no different, other than I don't have the auto slide forward feature on the passenger side like I did with the stock seat. Having said that, my sparco R100's are adjustable. If you go with non-adjusting Recaro's, it will be a different story.
On Instagram
On Wheelwell
Old 06-11-2019, 01:25 AM   #11
heeroyuy01195
Thanks! This definitely helps, probably won't be getting seats until next year. Need to do some work to the transmission first so that takes priority.
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 10:15 PM
FS: Wedge Brackets for Sparco Seats- $250 MGargano Items for Sale by private party 18 03-26-2012 11:14 PM
Sparco seats Sparcoboy General Yaris / Vitz Discussion 13 12-12-2011 03:19 PM
SPARCO shift knob & boot DieselPower Cosmetic Modifications (Exterior/Interior) 4 06-10-2009 09:31 AM
SPARCO GARAGE SALES 11/23 cali yaris California 6 11-21-2008 01:08 AM
