Old 07-23-2019, 05:37 PM   #1
stackman1
Drives: 2008 Yaris 3dr
Oil Change Accessories
Purchased a 2008 Yaris with 58,000 miles. Need to do my first oil change on it. Unfortunately due to apartment moves I had to jettison stuff like my oil drain catch pan and storage jug. Trying to remember the last one I used. Can anyone recommend a good catch pan? I went to Chris Fix's site and sees he recommends:
https://www.youtube.com/redirect?q=h...AxNTYzOTE0NzAy
I used to have a different style. Thoughts appreciated.
stackman1 is offline   Reply With Quote
Old 07-24-2019, 08:22 AM   #2
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
I have one similar to that, but the top isn't as deep. I got it at wal mart for like 12 bucks and works fine.
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 07-24-2019, 10:57 AM   #3
stackman1
Thanks Lee. Found it on eBay with free shipping for a couple bucks more.
Now, I just need to find a good spot to perform the oil change....
Old 07-24-2019, 05:10 PM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I use this:
https://www.amazon.com/Capri-Tools-C...dp/B00JJ63RNS/
Perfect size for the Yaris. Slides right under car. Can do oil change with the car on the ground. No need to jack it up. 2 gallon capacity. Very sturdy, integrated lip makes it easy to empty. I haven't spilled a drop since I started using it. 5 star item IMHO.
NYC-SE is online now   Reply With Quote
Old 07-24-2019, 05:30 PM   #5
NYC-SE
NYC-SE's Avatar
A nice little trick is to cut a Mobil 1 quart bottle in half to use as a funnel. The threads on bottle top match the threads on the valve cover. Just screw it in and pour. No need to do the one hand pour, one hand hold the funnel shuffle.
Old 08-03-2019, 12:06 AM   #6
bentjazz
Drives: 2009 Yaris--3dr MT
Just curious, how much does an oil change cost you guys when you do it yourself? I've taken mine to the dealer since day one, which in the long run is probably not the wisest move if I want to save money. And what do you do with the old oil once it's drained? Thanks.
bentjazz is offline   Reply With Quote
Old 08-04-2019, 08:30 AM   #7
Brettguy
Drives: 5 spd MT,black ASA iwheels
For mid priced synth oil and filter its about 30$ when I do it myself, been so long that I forgot what dealers and quick lube places charge ha. I hold up the oil into old jugs and whenever I have the time I just take them to advanced auto and dump it into their waste oil tank (I'm sure other stores have it as well).
Sent from my SM-N910T using Tapatalk
Brettguy is offline   Reply With Quote
2ZR Turbo Yaris 06YarisRS Forced Induction Forum 562 08-28-2025 02:49 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
First DIY oil change but... derickveliz2 DIY / Maintenance / Service 31 02-02-2009 11:36 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
