Drives: 2010 Toyota Yaris Sedan Join Date: Aug 2019
Brake caliper torque specs?
Hello all,
This is my first time changing the rotors and brake pads on my 2010 Yaris sedan. How would I find the correct torque specs for each bolt on the caliper? |
3 Yaris and counting..
Calibrated elbow. Not too tight! Lol
I honestly dont know. I'm sure someone here does. I've always just estimated. Hasn't failed me yet!
![]() Drives: 2010 Yaris LB Join Date: Jan 2019
According to the Haynes Manual, the spec for the guide pin bolt is 34 Nm (25 ft lbs) and the spec for the caliper mounting bracket bolts is 107 Nm (79 ft lbs).
I'd use some blue Loctite too.
Hmm good to know, I've always went with a couple ugga dugga's (SMA reference) on the 14mm caliper slide pin bolts and a few on th 17mm bracket bolts. Never had an issue in the track yet.
Yep, I am using these values as well. Works fine. No Loctite on threads. Waste of money (unless you have it for free).
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| Rear brake disks sliding bolt torque | Keymaster | DIY / Maintenance / Service | 6 | 04-12-2016 03:53 AM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| looking for torque specs on front caliper bolts 07 yaris | mikee07 | DIY / Maintenance / Service | 2 | 10-21-2012 03:36 PM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
