![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Yaris air bag light on off
Hi All
I am not sure what is happened but air bag light is blinking I had a broken underseat cable which i connected but light is still showing up. Any help would b highly appreciated. I have j2534 cable but on srs airbag it gave error so i am stuck. Thanks Sent from my SM-G930F using Tapatalk |
Any one ??
Knower of little
Drives: None Join Date: Jul 2019
I have no idea, I'd see if you can find a dealer/mechanic with the specific diagnostic machine to tell you what the problem is.
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
If you have a broken yellow SRS cable to one of the front seats then that's the problem. If you get it fixed then you can just disconnect the battery and the light will go off. With an ABS/SRS enabled scan tool you can read the ABS or SRS codes, a generic simple OBDII tool will only read check engine codes.
![]() Drives: Yaris 2007 3 doors Join Date: Jul 2009
that air bag warning goes on and off for me too , many times in 1 minute ,
at night the headlights go brighter when the air bag light comes on , if the wipers are ON , they go faster when the air bag light comes on , still looking for possible cause . just had 5 recalls done to the little car including the spiral cable that was said to make the air bag go On , did not change a thing ... |
#6 | |
![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
| Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR | toystory | DIY / Maintenance / Service | 43 | 04-17-2021 04:54 AM |
| Yaris crash, air bag did not deploy | IllusionX | DIY / Maintenance / Service | 46 | 12-23-2014 05:07 PM |
