Old 11-26-2019, 02:40 AM   #1
remcafee
Catless CEL problem
Hello, I recently did a straight pipe boom tube on my yaris and tried putting in an 90 degree o2 bung but it still shows p0420 code, anyone know of any tricks or hacks to bypass the p0420 code? thanks!
Old 11-26-2019, 06:58 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I have read about O2 simulators and they are available online but I'm not sure how well they work. I believe that Toyotas are pretty sensitive in terms of thresholds.
Old 11-30-2019, 01:50 AM   #3
remcafee
i saw those but im im as dumb as a rock when it comes to cutting wires and stuff ��
Old 12-04-2019, 11:27 PM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I have a 100cell race cat and I have an angled tube feeding the O2 but with only about a 5/16" hole actually feeding it
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 12-05-2019, 12:24 AM   #5
remcafee
what brand is your cat? you notice any piwer increase?
CEL afer oil pressure light andysong DIY / Maintenance / Service 8 03-06-2020 03:57 PM
Problem with electronic door lock new-yaris-owner In Car Entertainment + Electronics (audio / video / alarm) 7 08-05-2012 06:12 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
