Old 01-02-2020, 12:26 AM   #19
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Delete
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 01-02-2020, 12:30 AM   #20
myfirstyota
I've started a thread. Lest not give mighty car mods any more cred' on the title of this one!
Old 02-05-2020, 01:11 AM   #21
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
They just posted the dyno run for Yaris Hilton today - 150 kW (200 HP) at the wheels.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 02-05-2020, 08:26 PM   #22
Ausecho
Drives: 2000 3dr LB
Originally Posted by mitch9521 View Post
I wonder if you can get around that issue like MCM did by sticking the Corolla key near or attached to the transponder in the steering column. It'd be crude but it would get you running.
Australian models have transponder keys , you can just cut the chips out the key . Easy to get an new transponder key cut and programmed if the key that came with ecu is the MASTER key
Ausecho is offline   Reply With Quote
Old 02-05-2020, 09:04 PM   #23
Ausecho
Drives: 2000 3dr LB
They put it on the dyno https://youtu.be/K4UQsAe9-E4
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
