![]() ![]() Drives: 2009 Yaris 2dr Liftback Join Date: May 2019
Steering Squeeking
Greetings,
I have a 2009 Yaris Liftback (42,000 miles) that has a strange squeal/squeek when turning the steering wheel left. The issue occurs when the vehicle is stationary and turning at low speeds. The issue does not occur when turning right. I have recently installed TRD springs/shocks, new wheels, tires, and got an alignment. The problem may have been present before these changes were made, but I am not sure. The noise started out really faint and is progressively getting louder. Here is a link to the symptom: https://imgur.com/a/LUatpAE I am unsure of the cause. According to the 2007 service manual, the problem may be the electronic power steering motor, but I hope not. Does anyone have any ideas of the cause? Thanks. |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
Take a bottle of silicone spray, start spraying all the suspension components and see if that helps, like the control arm bushing, shock mounts, boots, steering knuckle and all of it
| No power steering on '08 Yaris after airbag recall done | madradjessica | DIY / Maintenance / Service | 14 | 12-18-2018 09:14 PM |
| DIY aftermarket steering wheel install with horn and airbag delete | tmontague | Performance Modifications | 19 | 11-30-2018 01:19 PM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 02:41 PM |
| Steering wander, adjusting EPS assist | Snubba | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-22-2012 06:39 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 11:16 AM |
