Old 04-21-2020, 11:06 AM   #1
Pinchlite
Drives: 2007 yaris HB
DSP install question.
I was told not to use RCA as this will disable HU volume control.
https://www.crutchfield.ca/S-EpDCGVb...EQ-S1000A.html
Basically where do wires (RED BOX ) go?
https://i.imgur.com/4TjyoIn.png
Could I use same wires that power my headunit to power DSP,Or run seperate designated?
I am using this to improve my android headunit soumd.
Basically this is a pioneer HU without screen.
Here is how I figure it should go...
https://i.imgur.com/vmCcDoQ.png
UPDATE:Just received unit.
The Instructions are vague at best and nobody has done video wiring install/turorial.
My understanding is all the speaker wires run into this unit.NO wires run into the Original headunit,accept the power/ground etc.
My question is how does the headunit know this dsp is even there with no communication between the both?
You would think there would be some sort of communication wire between the both?
Pic i took of wiring https://i.imgur.com/8KVpDHS.jpg
Or do I split all of the speaker wires and run into each unit?
Fog Light Install Question - Should Be a Piece of Cake for YarisWorld Veterans Tomatogrower DIY / Maintenance / Service 24 10-03-2014 04:38 PM
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
n00b suspension install question The Stig DIY / Maintenance / Service 25 07-12-2007 08:58 AM
question about radio install misfits9095 In Car Entertainment + Electronics (audio / video / alarm) 8 06-06-2007 03:08 PM
