#19 |
Dark is good. I really like them! You did a marvelous job. And, you created a little excitement on the yarisworld forum.
EDIT: I may consider painting the centre caps the same "root beer" colour and getting some black lug nuts. (But, I presume you're switching caps and lugs with your other set of alloys). Last edited by kimona; 04-29-2020 at 11:59 PM. |
#20 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
Almost looks root beer..ish. You did an excellent job.
#21 |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
WOW!
#22 | |
I have to do some measurements on the Hyundai wheel. The Yaris has a 54 mm center bore, but these caps vary from 52mm to 57mm. I think that's the outer diameter of the cap itself. But the Toyota caps actually recess into the Hyundai wheel. I think the 57mm cap would sit on top of the hole and not snap into place; not engaging the retaining tabs. https://www.ebay.com/itm/X4-TOYOTA-W...8AAOSwUqJdu7fL Or https://www.ebay.com/itm/X4-TOYOTA-W...IAAOSw1p1d-xfX EDIT: After looking at these caps again, they're kind of glossy. Maybe a more matte/flat would look better. I suppose I could clear coat them with a matte as long as the plastic didn't react adversely. Also thinking about satin or matte back lug nuts. Am I getting carried away? ![]() EDIT 2: If the silver caps I already ordered actually fit, I could just paint them satin black.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 04-30-2020 at 06:13 AM. |
#23 |
Thanks man. Yeah, makes me want to go to A&W.
#24 |
I think they're growing on me. We'll see with black lugs and center caps.
#25 | |
![]() ![]() Drives: 2008 HB Join Date: Dec 2012
https://www.good-win-racing.com/Mazd...t/61-2677.html Steve |
#26 |
As I said on the 'gram, I dig it.
Interesting that Kimona favors the darker, but doesn't like black wheels. I have black wheels, but as I commented to you on Instagram, think a shade or two lighter would work even better. Beauty is in the eye of the beholder! |
#27 | |
https://www.canadawheels.ca/fast-whe...dvehicle=81922 And for a bit more... https://www.canadawheels.ca/ultra-wh...dvehicle=81922
#28 | |
Edit: I'm actually thinking about applying a 2K clear coat over these wheels. It is advised against - being a 1K enamel - but if I dust 2 to 3 coats on and let them flash off, I might get away with heavier coats after that. I actually sprayed a little clear coat on one of the playing cards that had over spray on it. There was no adverse reaction. I'll give the wheels a couple of weeks to cure fully if I go ahead with this.
#29 | |
#30 |
They look great. What's the bolt pattern on these rims?
#31 |
Thanks. The bolt pattern is 4 x 100.
Here's an 'informational' video I put together: https://www.youtube.com/watch?v=y7noAaBv_5c
#32 |
Thanks, good info. And the center caps are the same size from accent and toyota ?
#33 |
Indeed they are for these models of Toyota and Hyundai. Not sure about other models.
#34 |
They look good. Great job with them!
| DIY aftermarket steering wheel install with horn and airbag delete | tmontague | Performance Modifications | 19 | 11-30-2018 12:19 PM |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
