Old 05-23-2020, 03:28 AM   #1
Branderrp
Drives: Yaris 2006 NCP91R
Front suspension boot cover broken
Hey all, was wondering if a loose boot cover on the front suspension will cause any trouble? I see a bit of rust on where the the cover was on normally.
Also, there's a bit of clunking noise when braking with moderate pressure when in drive (light braking is fine)
Notes:
- car is jacked up
- no play in the suspension (3-9 6-12 o clock hand shake test)
- no wobbles or clunks when driving normally (only when braking)
Edit: brake clunking disappeared when removing the swelled rubber in each lower guide pin caliper
Branderrp is offline   Reply With Quote
Old 05-23-2020, 04:52 AM   #2
dkwilfert
Drives: 2008 Yaris 2-Door (White)
That nice shinny clean metal shaft will become dirty, the dirt will begin to wear the seal into the strut body (shock absorber part), and the strut will begin to leak fluid and fail. Then you will need to replace the strut. Don't know if the boot can be repaired/replaced (others may know). If "yes", do it. If "no", drive the car till the strut fails and then replace the pair as a set. My $0.02
dkwilfert is online now   Reply With Quote
Old 05-23-2020, 08:33 AM   #3
komichal
the boot can be replaced but it is exactly the same job as replacing the whole shock absorber. I would say you can change the absorbers as well. BOTH!
Old 02-07-2021, 03:40 AM   #4
rayfloyd170
Drives: Yaris 2016 1.3 Manual
i have replaced these boots twice using Toyota genuine part but they fail roughly every 2 years... i dunno maybe because of the under washing which uses pressurized water with strong chemicals???
hope to have other alternative brands that are resistant and will last more than 5yrs...
rayfloyd170 is offline   Reply With Quote
Would these front suspension parts be any good? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 02-09-2017 10:07 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Torque Settings, front suspension Nimble Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-21-2007 01:00 PM
How can I cover front license plate hole hans_fh General Yaris / Vitz Discussion 13 01-03-2007 12:58 PM
