![]() Drives: Toyota Yaris 2016 Join Date: May 2016
Steering gear of an EPS system
Good day yarisworld!
Would just like to ask/confirm from you guys, is it true that the steering gear of an electric power steering system can be lubricated? I'm sorry I do not have enough car repair knowledge. I went to Toyota dealership 4 weeks ago complaining about the noise had it when I about to (approx. 1/4 from the center) turn the steering wheel (mostly audible) to the left at low speed. First diagnose was the spiral cable and then steering column but the noise was still there when they tested. After then, the service advisor came to me and said that they lubricated the steering gear and now the noise is gone. They said to just observe if the noise will come back. Luckily I haven't heard the noise until now. Thanks in advance. |
Drives: BMW Join Date: Feb 2022
Hi all! I am planning to open my car service center and would like to hear some tips on improving the quality of service.
![]() Drives: BMW Join Date: Feb 2022
Don't worry. You can lubricate the electric power unit and the hydraulic power unit to eliminate squeaky noise and extend the service life. You should use Litol, a universal grease for all mechanisms for this purpose. In answer to the question about the new car service, I can say that you should pay attention to CRM. It is software that will allow you to serve your customers much faster and better. The CRM also allows you to control all the operations in your car service. You can read more information about it on the Internet. I wish you good luck!
| Tags |
| eps, gear, noise, power steering, steering gear |
| Smooth gear transmission | AnaKara | DIY / Maintenance / Service | 4 | 07-30-2019 11:25 AM |
| 2014 Mazda 3 | Kal-El | Off-topic / Other Cars / Everything else Discussions | 32 | 11-08-2013 01:51 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 11:16 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 12:51 PM |
