![]() Drives: 2005 Toyota Vitz Join Date: Sep 2020
2005 Toyota Vitz 1KR-FE engine shaking
Hi Guys,
First of all, I am a new member. I have a 2005 Toyota Vitz (Japanese import). It has the 1.0 litre 1KR-FE engine. It tends to shake when the A/C is switched on and also sometimes without it. The whole car shakes sometimes. How do you go about fixing this problem? Thank you very much. |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
Thats the way it is with a 3 cylinder engine without balance shafts.
So no fix for that issue, if normal service is done.
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
Thanks for the reply.
The car shakes a lot, that's why I was concerned. So, according to you nothing can be done to sort this issue. It seems at times as if the car is going to stall... |
![]() ![]() Drives: Yaris T1 Join Date: Aug 2020
Saw a Suzuki Jimney behave the same way. Driver claimed that there was a loss of power.
Does that happen to you too? |
no. there is no loss of power.
thanks. |
| Tags |
| 1kr-fe, rough idle |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| 'Tik' 'Tik' noise for Vitz 2006 Engine | asimaleem | DIY / Maintenance / Service | 3 | 05-03-2015 01:37 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-06-2012 11:37 PM |
| GT5 Gran Turismo 5 | Bluevitz-rs | Off-topic / Other Cars / Everything else Discussions | 144 | 03-04-2011 09:13 PM |
| Toyota Vitz 2005 1.3L Auto Air Filter | technoguy | DIY / Maintenance / Service | 4 | 01-11-2011 02:45 AM |
