#91 |
2ZR swap. DO IT! Ask how!
Congrats! So glad you've got it back on the road and were able to work out all the details. It's good to get feedback on the EC60 vs the C50 since I've been considering sourcing one for my 2ZR daily driver. Seems like a lot of work for minimal gains, possibly even a net loss.
#92 |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
Yeah pretty happy with it so far and still kind of surprised that everything worked with no error codes popping up.
Regarding the EC60 box. Here's my list of pros and cons for anyone considering one, and I'd strongly suggest driving a Scion IM/Corolla before committing. Pros - Good shift feel - Easily accessible in Australia - Quaife diff available - The only 6 speed box that's going to bolt into a Yaris without modification to the chassis rail - Perfectly fine for every day driving - It's not an automatic LOL Cons - Requires custom or GRMN shifter cables - Requires GRMN gearbox mount - Short first gear (I find myself changing at around 20 - 25km/h) - Concentric slave cylinder - which can actually be a positive for pedal feel - High clutch engagement point - Limited to no heavy duty clutch options - Limited aftermarket flywheel options - 6th gear ratio isn't really any better than the 5th gear ratio in a 5 speed box. You're just getting one extra gear jammed in the mix. - No short shifter options or upgrades for the shifter cage I do know about the MWR options for clutches and flywheels. Though expensive options for Australia and I'd rather try and use the OuterPlus flywheel from Japan vs the MWR option. Though I wasn't about to drop $1000 on a flywheel :) |
#93 |
That's some good solid feedback on the 6-speed. I discovered the same thing when researching gear ratios for my custom 5-speed build (almost a decade ago?!?) and decided that it wasn't worth the hassle of notching the frame. That said, Project 2ZR Vios has that done and the 6-speed is absolutely worth it on the track.
That's a lot of weight to ship all the way around the world, for sure. I live only a few hours away from MWR and basically get overnight shipping for the price of 3-day ground. =) |
#94 |
I did some research last night into the ratios and interesting to see that the Lotus EC60 runs a 4.3x final drive with slightly different ratios on 4th, 5th, and 6th I believe. However the first few gears are the same. This is in comparison to the Corolla's final drive of 4.5x (can't remember the exact last number).
I think I would have preferred the 4.3 final drive in the Yaris. Ashame. The other thing to note though is that in theory, any upgrades for the Lotus Elise S3 gearbox should equally apply to the EC60. Gearsets etc...however everything I've seen has been extremely expensive. |
#95 | |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
R-CaT Project Yar 2ZR |
#96 |
Yes, it's the newer generation 6 speed when compared to the C60. It does however have a really short first gear. First and second ratios could have been a bit longer. There are a number of variations of the box with difference ratios, but we only got the one here in Aus.
#97 |
![]() Drives: Toyota Echo Join Date: Oct 2016
Is it possible to swap bellhousings on the EC and C series boxes? It'll be a great option if they can as you mentioned it being smaller and probably more plentiful
#98 |
Doubtful. What are looking to do? swap the EC box onto a 1NZ or 2NZ? If you want to upgrade the box on a stock Yaris, I'd look into gutting the existing box to replace it with different gearing and an LSD as well. The EC box isn't really worth it. Ratios are not great.
| 3rd Gen Gauge Cluster Swap :D | KenTK808 | Third Gen Yaris General Discussion | 22 | 10-21-2017 07:58 AM |
| 3rd gen header? | KenTK808 | Third Gen Yaris General Discussion | 2 | 01-16-2017 02:25 PM |
| Asking a quick favour from 3rd Gen Owners | kuveris | Third Gen Yaris General Discussion | 9 | 03-16-2016 12:08 AM |
| How to clean dash instrument panel? 3rd gen | Tgawe | DIY / Maintenance / Service | 4 | 10-11-2015 05:09 PM |
| 3rd gen 1zz tb swap | mr_miles | DIY / Maintenance / Service | 26 | 05-01-2013 08:20 AM |
