Old 01-29-2021, 01:15 PM   #1
EBeck
Drives: 2008 Yaris
Question 2008 Sedan no spark
Hello, My wife's 2008 Yaris sedan suddenly stopped while driving. I turns over but there is no spark. No codes stored in the ECU. Dash lights look normal. I checked all of the fuzes. Both the camshaft sensor and crankshaft sensor work (Make AC pulses when the engine is cranked). The ignition relay is also working. Grounds were checked and look good. No rpm detected on tach when cranking the engine. If the tach gets RPM from crankshaft sensor I wonder if this is telling me that its the wiring for the sensor? I am all out of ideas! Please help!
EBeck is offline   Reply With Quote
Old 01-29-2021, 11:34 PM   #2
Mazsive
Drives: Toyota yaris sedan 2007
Did you check that the fuel pump turns on and makes a sound?
Mazsive is offline   Reply With Quote
Old 01-30-2021, 01:52 AM   #3
EBeck
Drives: 2008 Yaris
fuel pump
I will check first thing tomorrow. Thanks. I dont have spark when I crank the engine so figured that would be the first issue to deal with.
Old 01-30-2021, 05:16 PM   #4
EBeck
Drives: 2008 Yaris
Thanks Mazsive! You made me stop and think....and I realized that when I was trying to check for spark I did not ground the spark plug....so yea I found today that I do have spark. Yep I bet its the fuel pump! Thanks for redirecting my efforts! Will report back
Tags
2008 yaris, crankshaft sensor, no rpm, no spark
Wind or bug hood deflector yaris sedan 2008 Red Horse Cosmetic Modifications (Exterior/Interior) 4 03-10-2016 02:02 AM
Install 2010 Front Grill in a 2008 Yaris Sedan dilandias General Yaris / Vitz Discussion 3 01-21-2016 11:37 PM
2008 Yaris Sedan Electrical problem VIP Asia 0 01-05-2016 02:49 AM
2008 yaris sedan airbag... Din get answer anywhere yet... Abk911 In Car Entertainment + Electronics (audio / video / alarm) 3 04-09-2013 12:33 AM
