Old 02-01-2021, 04:53 PM   #1
Farman
Drives: Yaris sedan 2019 eng 2NR-FE
I have parasitic draw in D/L No. 1 Fuse 25A
Hello everyone I have frustrating problem in my
Toyota Yaris sedan 2019 engine model 2NR-FE
After reconnecting negative 12V cable with multimimeter I have about 120-160 mA parasitic draw and with pulling out fuses I have found after removing 25A D/L No.1 Fuse. The parasitic draw becomes about 10mA.
As I have searched for this fuse i have found in net stands for "Power door lock system, main body ECU" in very close models.
My car had only one small accident in the back.
Now I want to know where to look to find the exact culprit? What is wiring diagram for this fuse?
Many thanks for your help
Farman is offline   Reply With Quote
#parasitic_draw
Question on Parasitic Draw rayfloyd170 Third Gen Yaris General Discussion 2 01-09-2020 12:03 AM
Parasitic draw kills battery BennyLava DIY / Maintenance / Service 7 12-23-2015 06:36 AM
power outlet/cigarette lighter fuse location Idahotom General Yaris / Vitz Discussion 1 01-08-2014 05:45 PM
help! parasitic drain from the fuse labeled "ECU B" rob_salsa DIY / Maintenance / Service 4 02-23-2012 01:28 PM
