![]() Drives: Toyota Yaris 1.3 2007 Join Date: Mar 2021
A/c problems
Hi all, my a/c has stopped working, I brought the car in November 2020
The owner then said he had the a/c recharged with gas, but now it not working The green light is on but I don’t hear a click or any Rev difference, does the Yaris 2007 have relays for me to check? Also is my a/c a clutchless type as it looks like It always engaged even when the a/c is turned off, I think maybe it shuts down when low on gas, any help would be great before I take it to a garage, Thank you |
#2 | |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
Okay I did think I might have a leak somewhere as the original owner mentioned to me a few times he’s had the a/c re-gassed, so it’s the a/c clutch supposed to always be engaged even when turned off in the car?
Thank you |
Our compressor has an internal clutch. Visually, it appears that the clutch is always engaged.
You need to get a pressure test done as a first step. If you're low, then you have a leak. If pressure is fine, then your next likely point of failure is the pressure sensor. Failure of that component is rare but is exactly what shut my a/c down.
| Trouble with a/c | vrg2016kr | DIY / Maintenance / Service | 2 | 07-03-2020 06:50 PM |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Clutch Compressor question | tmontague | DIY / Maintenance / Service | 3 | 05-11-2014 07:57 AM |
