![]() Drives: Yaris Join Date: Jun 2021
P1693 OBD code
Hi everyone, first time posting here.
I bought an older Yaris, however it seems that I may have bought a cat in the bag. On the test drive and after that it seems to mostly drive ok, but it turns out it has disabled/burned out CEL light, and on the scanner the P1693 code is showing up. Now, after a brief googling, I could not properly verify it, but it seems to point to VVT solenoid, but some mention something with turbo (which 1.0 petrol obviously does not have). Any ideas? Thanks in advance! Edit: Forgot to mention: 2001, 1.0 petrol engine |
This might be as simple as the bad oil pressure sensor. I would probably start with that. But no guarantee this will solve it - at least you will eliminate one possible source of the problem and it is not expensive.
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Sounds like you're on the right track. See if you can locate the VVT-i solenoid and clean it, I believe it also has a filter. Parts/brake cleaner should be safe enough.
Hi. Thanks. By oil pressure sensor do you mean the oil pressure switch?? I could not find anything else.
#5 | |
Resistance seems to be within specification. I wonder what the voltage coming from ECU should be. With ignition on, it is 6.4V. I have no idea is it as it should be or not. As to mesh filter - it is there on the parts list, but for the life of me I cant find where it is. Some sources say that it does not have one at all. I am getting more questions than answers :( |
| The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) | Darb | Off-topic / Other Cars / Everything else Discussions | 86 | 10-18-2017 09:03 AM |
| Strange OBD II code: C3201 | CrankyOldMan | DIY / Maintenance / Service | 10 | 09-29-2015 10:58 PM |
| P0010 OBD engine Code | crazylegs | DIY / Maintenance / Service | 1 | 08-27-2015 08:27 PM |
| full tank | japle | Fuel Economy Forum | 15 | 12-10-2013 12:05 PM |
