Old 09-07-2021, 08:42 AM   #1
Naxa
Drives: 2008 Toyota Yaris Sedan
Help- P0301 Code
Yesterday, I got the P0301 code upon starting up my 08' Yaris Sedan. About 7 months ago the previous owner of my car changed the spark plugs (they did not change the coils). About 4 months ago, the CEL flashed above 3000 RPM, the engine was running rough, and I turned the car on and off and I did not have this issue, and eventually the light went away.
I cleared the code yesterday and the engine has been running with no issues ever since, so I cannot get the misfire to happen consistently, only rarely.
What is my best course of action?
Naxa is offline   Reply With Quote
Old 09-07-2021, 01:49 PM   #2
iOLO
Drives: Yaris
Chances are its the coil or spark plugs. If you want to be proactive you can switch the plugs and packs on cylinder 1 with cylinder 2 and see if the code trips p0302 down the line. Might also be a good idea to check the plugs anyway to see condition to ensure cylinder 1 isnt leaking oil on plugs or if its warn out. Might wanna change the coil for 1 either way if spark plug is clean.
iOLO is offline   Reply With Quote
Old 09-07-2021, 03:06 PM   #3
bronsin
bronsin's Avatar
Simple. When it comes back swap coils see if it comes back with the coil you installed in the air code. Then change to a new coil.
Or swap spark plugs and read the code when it comes back. Then buy a new plug
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
Testosterone: The New Synthetic Oil bronsin Off-topic / Other Cars / Everything else Discussions 23 12-15-2013 06:02 PM
full tank japle Fuel Economy Forum 15 12-10-2013 11:05 AM
Sponsors List RogueYaris Sponsors Classifieds Area 14 01-05-2013 10:23 PM
