Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 10-10-2021, 05:20 PM   #1
corradovr6
Drives: yaris 2002 t sport
exhaust drone
Recently joined the forum - really good site and loads of great info!
Bought t-sport 2002 recently and have been working my way through rectifying niggles etc. One such annoyance is the droning from the exhaust from around 2500 to about 3200 rpm. Really very intrusive in the cabin. It looks like the rear heat shield may not be there as the boot carpet and floor area get quite warm too - i've just added a few layers of Damplifier there as the floor is really thin! Just wondering if the two are related?
Anyone else had that drone and if so, what did you do to reduce it?
Thanks
corradovr6 is offline   Reply With Quote
Old 10-25-2021, 02:10 PM   #2
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
They are high revving tin cans at the end of the day. But as you already said sound deadening mats make a huge difference.
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 12-04-2021, 02:06 PM   #3
corradovr6
Haha good description! Just changed the backbox which has reduced the drone but at 2500 to about 3000 its quite prominent. My old 1.3 cdx never had this and as they're practically identical (2nz and 1nz) i assumed it would be the same here?
Does adding weights to the exhaust do anything?
Old 01-18-2023, 06:49 AM   #4
Abboodeh
Drives: Man
Send a message via ICQ to Abboodeh Send a message via AIM to Abboodeh Send a message via Yahoo to Abboodeh
@pump_upp - best crypto pumps on telegram !
https://t.me/pump_upp - best crypto pumps on telegram
Make 1000% and more within 1 day, join channel @pump_upp !
Abboodeh is offline   Reply With Quote
Old 03-08-2023, 04:12 PM   #5
Kellyw
Drives: 2008 Toyota Yaris Hatchback
Hi, I was wonder what the difference between a 2008 Yaris Hatchback and a Sedan Exhaust.
Kellyw is offline   Reply With Quote
Old 03-08-2023, 04:19 PM   #6
Since the distance between the rear axle and the bumper on the sedan is significantly greater than the hatch, the sedan muffler assembly is much longer.
Old 03-08-2023, 04:20 PM   #7
Kellyw
Is there a difference between a 2008 yaris Hatchback and a Sedan Exhaust? I can't find a answer. Thanks
Old 03-08-2023, 04:24 PM   #8
Kellyw
Someone stold my exhaust and I bought a new one. I needed a Hatchback and they sent a sedan, I think. I cut it down to fit but for some reason it is hitting against the floor when you put it in gear?
Old 03-08-2023, 04:29 PM   #9
Kellyw
Thanks
Old 03-08-2023, 04:30 PM   #10
Kellyw
Old 12-21-2023, 11:15 PM   #11
WorldTraveler
Drives: 2009 Toyota Corolla
Good work figuring it out! Steering wheel control wiring can definitely be tricky. I'm always impressed by people who take the time to DIY install their own stereos - saves a bundle over paying a shop to do it.
WorldTraveler is offline   Reply With Quote
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
