![]() ![]() Drives: . Join Date: Mar 2019
Front Driver Side Seatbelt Removal
I guess it's time to fix my sagging seat belt.
It doesn't retract fully and gets caught in the door and just looks bad. Are there any tricks for the full assembly removal or is it the standard 3 or 4 bolts to the frame like the older cars? (I couldn't find any pictures, videos, or manuals) Should I try to fix the assembly on my own (manually tightening the spring) or is it better to send it in for service? Or does anyone know where I can purchase a new assembly? (2011 Hatchback in the USA) |
![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
Try this first at no cost : https://www.youtube.com/watch?v=8XL8QbooM84
yeah its a simple remove, 3 bolts and a plug
tho you do need to remove the trim too and the upper "slider" is a lil tricky as you have to pop up the fingers on the button to access the bolt |
| Help! Right side lower control arm removal | RUBBERDIPSTICK | DIY / Maintenance / Service | 15 | 12-27-2018 02:29 PM |
| Water leak to passenger side AND driver side | TMR3 | DIY / Maintenance / Service | 7 | 05-21-2017 08:19 AM |
| Driver Side Door Not Open From Out Side | DigitalGuy | DIY / Maintenance / Service | 2 | 10-17-2016 07:07 PM |
| Very strange clunking from driver side tire - everything tried so far no go? (2007) | KorJax | DIY / Maintenance / Service | 22 | 12-09-2014 03:50 PM |
| Driver Side Wiper Issue | justfillingtime | DIY / Maintenance / Service | 2 | 02-15-2013 09:08 AM |
