Old 09-27-2022, 09:56 AM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
brake light
Hi Yarisworlders. My brake light is coming on then going off. It'll come on for a little while, then go off for a little while. Has anyone else had this happen, and if so do you know what it could be? I have a 2009 manual. Thanks.
bentjazz is offline   Reply With Quote
Old 09-27-2022, 10:05 AM   #2
External brake light, or instrument cluster light?
Old 09-27-2022, 11:12 AM   #3
bronsin
bronsin's Avatar
If it’s the instrument cluster light you got a problem. How’s the level of brake fluid in the master cylinder? It gets very low as your front brake pads where you might need new front brake pads. Do you have a scan tool and are there any codes?
Old 09-27-2022, 05:33 PM   #4
bentjazz
I forgot to mention I did have the brake fluid changed, as it never has been changed before to my knowledge. I hate to admit it, but I'm not sure what the difference is between the external brake light and instrument cluster light. The light that is on/off activated spells out "brake" and it's below the speedometer, if my memory serves me correctly. Thanks, guys.
Old 09-27-2022, 05:37 PM   #5
bentjazz
Also, bronsin, it seems the brake fluid level appears to be stable.
I think I understand the difference between external and instrument cluster. It's not the external brake lights in the back of the car, but the "brakes" light in the instrument cluster.
Old 09-27-2022, 05:49 PM   #6
bentjazz
bronsin, no. I unfortunately don't have a scan tool. I've made an appt. at the dealership this week. I hope it's not too much money.
Old 09-27-2022, 05:53 PM   #7
bronsin
bronsin's Avatar
Good luck and tell us what happens!
Old 09-27-2022, 06:44 PM   #8
bentjazz
Thank you, bronsin. Will do, for sure.
Old 10-01-2022, 02:49 AM   #9
bentjazz
Took it to the dealer and it turned out they didn't tighten something when they swapped the brake fluid, which led to a leak. They fixed it up for me and stopped the leakage. Glad it wasn't something expensive....
Old 10-01-2022, 08:31 AM   #10
bronsin
bronsin's Avatar
Well at least it’s fixed...and no accident resulted from the dealer induced leak...
Old 10-01-2022, 01:06 PM   #11
bentjazz
True that, bronsin. Grateful for that, for sure.
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
2007 yaris hatch back 3rd brake light (stop light) MegaMatt DIY / Maintenance / Service 12 06-15-2015 10:55 AM
Speedometer, brake light, odometer all gone weird boneyking DIY / Maintenance / Service 0 07-01-2014 01:30 AM
Emergency brake light is on constantly AdeJong 03 DIY / Maintenance / Service 9 10-10-2009 09:32 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
