GRIDLIFE Sundae Cup Yaris
Drives: 06 CDN Yaris Base Join Date: Apr 2017
Honda Fit Wilwood Calipers on a Yaris?
Ok so I am in process of building a track Yaris and I think I have the rear disc conversion figured out, but I want to add some more stop to the front. I have looked at the drawings for the Wilwood Honda Fit caliper kit and it appears that they use the same bolt spacing as a Yaris, 140mm. Has anyone attempted this before or am I going to be the first? Pics for fun:
![]() ![]() Drives: '07 Yaris Liftback Join Date: Jul 2007
I'm redoing my wheel bearings and can confirm the mount center is 140mm, however the bolt circle radius is smaller on the Yaris ≈ 95mm vs the spec'd 100.4mm, so the caliper will be too close to the spec'd rotor.
![]() ![]() The Dynalite kit has an intermediate mounting bracket that could be replaced with a custom one if you wanted to look into it. Additionally, I know they're not a big name, but Ceika has a customizable kit with more options. |
You are the man for this info! Thank you!! So, the Fit uses a 262mm rotor and the Yaris a 255mm rotor for a 7mm difference in diameter. Do you think it is possible it could work using the Yaris rotors instead of the Fit rotors?
I really want to go wilwood just for the brake pad options. Not many options exist for the NCP91 and having the ability to quickly swap pads with all sorts of compounds would be stellar. |
Yaris rotors are 22mm wide vs 20.8mm on the Wilwood DPHA kit you're looking at. The Wilwood Dynalite kit is probably a better option if you want Wilwood rotors and pads. Just need to fab a custom bracket for the caliper (part 1 in the drawing).
Well I think I may just go with SE brakes.. I was reviewing the rules for GRIDLIFE Time Attack Street class and I actually can't run wilwoods
the SE conversion goes to 275mm and has no issue, so your wilwood brakes @ 262mm should work, with very small risk of shaky braking because of it not being hubcentric. the rotor thickness i dont think even matters as long as the caliper, in this case is made for it?
thought about OEM euro GRMN/GR sport 2016-2018 4pots? or the ENDLESS 4pot calipers for the RS (SE model here)? |
![]() Drives: Beater 10 yaris 3dr HB XP90 Join Date: Oct 2025
Any updates on this? No info for brackets made without buying a complete setup so far
| Chose Yaris over Fit? This is how many miles you can drive it for free on the diffrnc | john21031 | General Yaris / Vitz Discussion | 52 | 09-09-2011 10:25 AM |
| Test drove Rio5, Fit, and Yaris all today | kmf123kmf | New YARIS Purchase Forum | 16 | 10-02-2009 07:48 PM |
| Will honda fit rims fit on a yaris. Meaning are the hubs the same bore? | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 12-24-2008 03:09 PM |
