Old 01-13-2016, 07:27 PM   #127
Kar98
Drives: 2011 Scion tC
Originally Posted by Frank the Tank View Post
More info needed.
Also what year rav4
Says RAV4 07, so I'm gonna assume it's a RAV4, from '07. What other info do you need? The stalk swaps right in with no further modification needed.
Kar98 is offline   Reply With Quote
Old 01-13-2016, 09:31 PM   #128
tmontague
tmontague's Avatar
If you remember correctly, that is the same stalk I installed last month on my sedan. Works like a charm, I have no idea how I went this long without it, rainy days are much easier to deal with now
Old 01-14-2016, 12:25 PM   #129
Frank the Tank
Drives: 2007 Toyota Yaris
http://m.ebay.ca/itm/Toyota-Matrix-P...055?nav=SEARCH
Would this work?
Frank the Tank is offline   Reply With Quote
Old 01-14-2016, 12:45 PM   #130
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
If it's Prius compatible, i don't see why it shoudn't work.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 01-14-2016, 03:37 PM   #131
lambros
lambros's Avatar
Drives: TOYOTA YARIS S 2009
https://lh3.googleusercontent.com/oH...=w1280-h720-no
This is mine before installation...code 84652-48060 from previus models but I like it more because writes words MIST-OFF-INT-LO-HI and not just icons.....
lambros is offline   Reply With Quote
Old 01-14-2016, 03:47 PM   #132
jcboy
Drives: Sedan 07
Originally Posted by xavi_3d View Post
Hello, can please anyone tell if this one will work?? It's from a 2010 avensis
No.
HI Scott, i know you are sure, but mine's pretty similar to this, and it works.
Old 01-14-2016, 04:37 PM   #133
MUSKOKA800
MUSKOKA800's Avatar
And, as the sedan doesn't have a rear wiper can we assume the Camry's stalk would be in play for us?
Old 01-14-2016, 05:09 PM   #134
Frank the Tank
Link doesn't work
Old 01-14-2016, 11:40 PM   #135
tmontague
tmontague's Avatar
I dont know if you camry one would work or not. I have a liftback version on my sedan and it works fine, the rear wiper switch just doesnt do anything
Old 01-15-2016, 10:15 PM   #136
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Does anybody know if this will work on a 3rd gen Yaris? What part number if so?
NYC-SE is online now   Reply With Quote
Old 01-19-2016, 08:58 AM   #137
lambros
lambros's Avatar
What about mk3 and intermittent wipers? It works to new Yaris?
Sent from my iPad using Tapatalk
Old 04-11-2016, 02:49 PM   #138
Frank the Tank
OK, so CTscott says the 84652-48060 won't for work hatchback rear intermeniant wipers but lambros says it works for his.
For the people who got their rear wipers to have a intermeniant setting, can you post up your part numbers?
Old 04-11-2016, 07:51 PM   #139
I don't specifically say that it won't work. I only listed the ones I was sure would work. If someone else tried the 84652-48060 and it worked, then it will for you as well.
Old 04-11-2016, 09:59 PM   #140
bairjo
Jeez...I get the impression folks on here think that Scott is a human catalog of "what if" parts to try. The man has supplied info on what works and works well....so I go with what he has researched and proven. why not? His info is bullet proof in my mind.....not questionable like some info on this thread.
bairjo is offline   Reply With Quote
Old 04-15-2023, 07:12 PM   #141
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
Can confirm that part number 84652-04141 (for Tacomas/Tundras) works in my 2007 sedan. Got an aftermarket switch off ebay for a fraction of the price of the OEM unit (~$50USD). Functions and looks identical to OEM, but the "click detent" might not be as nice when physically moving it. Relay is also a bit more audible, but not enough to drive me bonkers or anything. Time will tell how it holds up. Thanks for sharing this guide!
Kasbien is offline   Reply With Quote
Old 06-25-2024, 01:18 AM   #142
KermitAUS
Drives: Yaris 2009
Hi,
Has anyone done this for an RHD Australian Yaris?
KermitAUS is offline   Reply With Quote
Old 06-25-2024, 01:47 AM   #143
KermitAUS
Drives: Yaris 2009
Anyone done this for a RHD?
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
