Old 09-11-2024, 10:23 AM   #1
woodamsc
Drives: 2008 yaris sedan
Troublesome MAF Sensor Circuit Low code
2008 Yaris Sedan, ~190k miles
Bought it at 180k, was running fine for a bit then I started getting cylinder 4 misfire code, and then next day MAF sensor code.
Main symptom was warm starts caused rough idle, driving would usually resolve the rough running.
I just decided to start changing stuff that was likely overdue anyway rather than diagnose
Most of the stuff I changed truly did need changing
  1. I changed Sparks + Coils => car drove MUCH better, but codes remained
  2. Cleaned MAF Sensor with MAF cleaner. It was absolutely covered in crud. => car drove even better, absolutely mint. Couple days later cylinder 4 misfire. Couple days after that, MAF sensor code returned
  3. Cleaned PCV Valve with MAF Cleaner. It was totally gummed up. => Car runs better. Cylinder 4 misfire code has NOT returned, MAF Sensor Circuit Low HAS returned.
  4. If I unplug MAF Sensor while car is running in park, car immediately dies.
Should I just cough up $90 for a new MAF sensor? I can't help but feel the sensor is OK sense the car dies when I unplug it. Maybe a grounding issue?
Currently car runs and drives, but I feel like it's in a limp-mode of sorts. It isn't running ROUGH, but it doesn't feel full power.
Car starts rough, like a there's a slight hesitation, and then it rocks around a bit before it sorts itself out.
Since cleaning the MAF + PCV I've driven maybe 200 miles. I was thinking ECM needed time to adjust the fuel trims or something.
If it's not a bad MAF, what would be left to check? A clogged fuel injector?
At this point I need to diagnose rather than keep throwing parts at it haha
woodamsc is offline   Reply With Quote
Old 09-11-2024, 12:06 PM   #2
Is the o-ring gasket on MAF intact and providing a tight seal?
Old 09-12-2024, 02:42 PM   #3
woodamsc
I believe so, but ill check for certain when i return home, and look for any other leaks. I changed the air filter recently as well
Old 09-15-2024, 10:28 PM   #4
woodamsc
Yeah everything looks good. I didn't see any cracks on the intake hose either.
Old 10-13-2024, 10:56 PM   #5
woodamsc
New MAF Sensor solved this
DRL: Low beam or -lamps - or not? Ot_tO General Yaris / Vitz Discussion 10 07-27-2012 08:11 AM
I have a MAF code p0100...:-( Motorhead General Yaris / Vitz Discussion 2 03-28-2011 07:23 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 07:56 PM
