Old 10-19-2012, 10:53 AM   #1
raysau
Drives: 2000 toyota yaris
Smile Relays
could someone please tell me where the headlight relays are on a 2000 toyota yaris 1.0? as I cant find them,perhaps it has none,hoping someone can help.
raysau. r.saunders682@btinternet.com
raysau is offline   Reply With Quote
Old 10-19-2012, 12:29 PM   #2
They are under the hood, in the square relay box that is behind the main fuse panel, against the side of strut tower.
Old 10-19-2012, 02:54 PM   #3
raysau
To CTScott Thanks for your help with regards to Yaris relays,but I have allready looked in the fuse relay box under the bonnet but Iam unable towork out whitch are the headlight relays,I have had someone turn the lights on but did not hear a click or anything else,still thankyou for your help
raysau.
Old 10-19-2012, 03:14 PM   #4
Ah, I see that if you don't have daytime running lights, then there are no relays. The switch drives the headlights directly via H-LP RH and H-LP LH fuses.
Old 10-19-2012, 06:24 PM   #5
raysau
Thanks CTScot That was all I needed to know, thats why I cant see them in the haynes wiring diagram.
Thanks very much for your help,so back to the drawing board.
raysau
Old 06-16-2025, 07:00 AM   #6
andon0v
Drives: Toyota Yaris MK1
I have Toyota Yaris MK1 with 1.3 2nz-fe and don't have daylight running lights. Guys is true that the low and high beams don't have relay, but fuse directly from battery and the ground is through the steering column switch? Thanks in advance!
andon0v is offline   Reply With Quote
Water Leak! Failed Relays cfeng DIY / Maintenance / Service 0 12-13-2010 05:21 AM
