Old 05-21-2007, 01:52 PM   #1
hans_fh
Drives: Yaris
How can I remove hub caps?
Just wondering why many people removed their hub caps?
How can I remove that?
Thanks a lot!
hans_fh is offline   Reply With Quote
Old 05-21-2007, 01:54 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
hands seem to do the trick... that was all I needed... and a little effort
Old 05-21-2007, 01:54 PM   #3
ChinoCharles
Drives: LB
Pull them off! If you can't muster enough muscle, just use something to pry them off like a screwdriver. You won't break anything.
And yes, a lot of us are rolling without hubcaps. Check out the Yaris Garage for pictures.
Old 05-21-2007, 01:57 PM   #4
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
I used a wooden tapperd shim to gently get them started without marring the wheel. When I got them just started I pulled them off with my mits.
blacksan is offline   Reply With Quote
Old 05-21-2007, 01:57 PM   #5
kurokoma-kun
Drives: 2007 Yaris HB
Not hard at all. They are held on with a wire ring that is snapped into clips on back side of wheel cover. My hands were not stronfg enough--I had to feel around for the wire then get a screwdriver under there and pull.
Old 05-21-2007, 02:00 PM   #6
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
You'll have to take the car to the dealer. They have a special Hubcap Remover Tool.
No seriosuly, I pulled mine off with my teeth.
SPONSORED BY
Old 05-21-2007, 02:01 PM   #7
blacksan
blacksan's Avatar
You mean you used your head like a bottle opener?
Old 05-21-2007, 02:34 PM   #8
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
If you have the locking kind, then it can be a little tricky. I would unlock it first THEN pry it off...you know, like when you go to change a flat tire. BUT first I would put the car in "park" then engage the emergency brake (the handle with the button on the end between the two front seats). Now, when you go to pry off the hubcap you want to make sure you do not mark up your tire! As far as putting it back on..well, er....I never went that far so I couldn't tell you how to do that. Maybe some Gorilla glue?
sambo42xa
sambo42xa is offline   Reply With Quote
Old 05-21-2007, 02:38 PM   #9
YamilR
YamilR's Avatar
yea you don't want to void the suspension warranty
Old 05-21-2007, 03:04 PM   #10
blacksan
blacksan's Avatar
[QUOTE=YamilR;88308]yea you don't want to void the suspension warranty[/QUOTE
Your cool on that unless you replaced the stockers with the lowered hubcaps.
Old 05-21-2007, 06:31 PM   #11
uncleyaris
I had mine off about 5 seconds after I got the keys. They look horrible IMO. Looks better with just the Steelies for sure.
Old 05-22-2007, 08:05 AM   #12
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
yeah the guy at the dealer was speachless when i took the keys and was prying the hgub caps off in the dealer lot i peeled the dealer sticker off put my licensplate in the front window and said see ya!
d2dailly is offline   Reply With Quote
Old 05-22-2007, 10:12 AM   #13
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Just grab and rip them right off grizzly style. Piece o' cake!
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 05-24-2007, 02:05 PM   #14
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
i might be he only one that like his hubcap but as soon as I can have some spare $$ new wheels
the_boss is offline   Reply With Quote
Old 05-24-2007, 02:34 PM   #15
blacksan
blacksan's Avatar
Dude, your hubcaps rock!!!
BTW, is that picture from today with snow still on the ground?
Old 05-24-2007, 02:45 PM   #16
the_boss
the_boss's Avatar
no that's a pic from the day I got the car in april...Now i have a short antenna and lawn
White Disc Hub caps - Yay or Nay? (the chino opposite) vodkalush Wheels, Tires and Suspension Forum sponsored by The Tire Rack 62 07-23-2007 07:40 AM
4 Hub Caps from Toyota Yaris 15" Wheel Covers jamal1984 Items for Sale by private party 0 04-16-2007 09:46 PM
(4) Genuine Toyota 15" wheel covers, hub caps *new* flint_mica_manual Items for Sale by private party 0 04-16-2007 08:47 PM
Need Help on finding 15 inch Hub Caps jamal1984 Cosmetic Modifications (Exterior/Interior) 18 03-31-2007 01:12 PM
WANTED - Stock 15" 2007 Yaris HUB CAPS! Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-29-2006 07:09 PM
