Old 06-21-2007, 06:22 PM   #1
i'm using the S.Tech's. never needed an alignment. the car drives straight. i haven't noticed any camber changes either. then again, i'm also using the TRD Sportivo shocks, so i don't know if that makes a difference.
Old 06-21-2007, 07:15 PM   #2
The Stig
The Stig's Avatar
Drives: 07 LB MM 5spd, 99 M Coupe
same here just going to ride on the stock steelies for a little more to see if any strange tire wear or mystery rubs or what not....
The Stig is offline   Reply With Quote
Old 06-21-2007, 11:13 PM   #3
dallas
Drives: Yaris Hatch /Landrover D2
Thanks guys, check your tire for uneven wear, when you lower a car, After a drop you get negative camber which should accelerate tire wear. Unless you get an alignment. Has anyone gone for an alignment after the install. Do the teins bounce or pogo on the stock struts? They must be great on the sportivo's.
The Stig;100873]same here just going to ride on the stock steelies for a little more to see if any strange tire wear or mystery rubs or what not....[/QUOTE]
dallas is offline   Reply With Quote
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
Tanabe NF210 spring install help Jerkratt Performance Modifications 8 06-08-2007 10:13 AM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 08:32 PM
