Novice Hypermiler
BailOut is such a loser!
Just Kidding, congrats on the second CleanMPG home page stop! http://www.cleanmpg.com/forums/in-th...mile-5166.html |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
lol, nebulight
![]() Thank you for the congratulations! That is a nicely written hypermiling article.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
congrats. the most i've gotten was 51 mpg. and that was some time back...
Do you Still have your back Seat? When I too mine out I got 4.6% increase in Gas Milage... And I drive like the Yaris is a Corvette!
*Philosophy of life... Brought to you by... "Nutzoids" Nutzoids... Where Punk rock is less about Image, and more about the Mind! |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
when I pulled my back seets on a recent expressway trip I pulled 52 mpg... and that was with 35 psi in my 17in tires, at 80 mph, not using any of Bail out's MPG tips, so I wonder if all those tips realy help?
BTW I do run premium fuel, and 0w-20 full synthetic oil and have a CAI, header, and exhaust wich all contribute to a more effecent motor therefor better MPG.
#6 | |
Cybernetic Magician
![]() ![]() Drives: Bayou Blue 2dr, AT Join Date: Jun 2007
Direct link to the article: http://www.tahoebonanza.com/article/...220043/-1/NEWS
#8 | |
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
#9 | |
i don't do jack rabbit starts and i shift (if you have a mt) no later than 2,500 rpm. |
#10 | |
Novice Hypermiler
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
Well, BailOut gets amazing mileage not necessarily because he's driving a Yaris, but because of his driving technique, and the way he does it can't be always considered as a "normal driving" - such as turning off the engine on downhill or excessively inflating the tires way above the engineering recommendations. With some of the techniques he uses, anyone would achieve better mileage, even with cars like Escalade or Tahoe.
If one drives on highway at 50 mph instead of 65, this will increase up to 15-20% the mileage, however is it 50mph a practical speed in todays life style ? I would drive my car at 35mpg on highway (slowest speed allowed) and tell you about 70MPG or more, would that be reasonable ? That said, I agree with many of his driving techniques, that could easily be used by anyone with better mileage as a result, such as shifting limits or avoiding excessive speeds |
#12 | |
To make a long story short, my daily commute traverses 4,500 vertical feet over the highest Sierra Nevada mountain pass that is maintained year round (Mount Rose - Nevada SR 431). The twisting, winding, road always has sections in poor shape due to the snow plows and runoff, it has several climbing, 20 MPH hairpin turns, the grades often exceed 6%, the winds are almost always high, and the summit is at 8,900 feet. Stock intake with a K&N panel filter. Stock exhaust. Stock wheels and tires (with higher PSI in the tires). The back seats are still in. Regular gasoline (87 octane) with E10 (State requirement). 5W20 synthetic oil. I have only spent USD $88 on after market "performance" parts ($22 for the K&N panel filter, $34 for the block heater, $32 for the solar trickle charger).
der Zeck
the reason I stated my mods is I realy do not care about my MPG I just wanted to see what mine was on my trip to Dexter so that I could post it in one of these threads.... I do not do one thing you suggest and I can achive the same gas mileage, and I have my car geared toward preformance.... now tell me that is not funny
#14 |
Black Yaris, I think you misunderstand the difference between our geographical situations. Come do my commute for a week or two and see if you can still pull 52 MPG.
#15 |
Indeed, I think Ohio is not exactly well known for its towering mountains
#16 |
der Zeck
I understand, I am not saying you specificly in your situation, I am only attacking the theories.... others use them in the same climates and/or geographical situations as I, with similar stock setups as you with out very good results. I am just stating the fact that I can pull the same mileage with preformance mods wich actually just make the motor just more effeciently, the HP is there when I get on it, and the mpg are there if I were to actualy care...
#17 |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
The gated shift of the automatic is ideal for the downhill coasting (I never shut the engine off though). If I drove 50 or under I could probably coast 1/3 of the way to work and back (20 miles each way). But I drive 60-65 and the hills aren't steep enough to maintain speed (unless wind is in right direction), except for one hill each way that's about 1 mile long and brakes are required. Anyway....at 4,000 miles I put 44psi in, lowered the car, and cosistantly coast these 2 hills-----my milage went from 36 avg to 40 avg, and I have 11,000 miles on now. Haven't been below 40 mpg for the last 2,500 miles.
Don't have a scangage so can't really verify...but isn't there a point where if half your miles use 'zero' gas, and if your uphill driving doesn't reduce the milage in half of the flat land milage, can't you gain milage? Don't the hypers have a technique (I wouldn't recomend in daily driving) where they slowly accelerate then coast repeatedly on flat land? This would seem to be in the same category.
____________ Old School Cobble Jockey
#18 |
der Zeck
see I was going 80 the whole time
