Old 06-25-2007, 07:00 PM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by WRBlue View Post
The rest of the world measures octane different than us in North America. In the EU and Australia, they advertise RON. Here we use an average of RON and MON. MON is a lower number than RON. YOU CAN'T COMPARE OCTANE RATINGS BETWEEN NORTH AMERICA AND THE REST OF THE WORLD.
The ignorance in this thread makes my head hurt.
Octane only measures the autoignition characteristics of gasoline. How easily it will explode without a spark.
THE ONLY THING THAT WILL CAUSE MPG TO INCREASE ARE O2 READINGS.
If the O2 sensor reads the car running rich, it'll lean it out within safe parameters. Lean = less fuel used = higher MPG.
HIGHER OCTANE DOES NOT CHANGE THE AIR-FUEL MIXTURE.
Higher octane gasoline can only prevent detonation. If your detonating with 87 octane, something is wrong with your engine/ECU.
A car runs a base timing and advances or retards it only within set parameters. And those parameters are ones set by Toyota Engineers as to be safe with low octane gasoline. The computer will not exceed those if you put high octane gas in and magically the computer knows.
Besides, there is no sensor that can tell what octane is used. To measure octane, you have to find out the percentage of volume is iso-octane and the percentage of volume is heptane. NO production car has the ability to do that...
And anyway, advancing timing does not cause less fuel to be used. It cause more power to be made from the fuel.
Everything else in this thread is anecdotal evidence. There are many, many, many variables. Elevation, wind, drag, tires, air pressure, surface type, load, weight, etc. The most important thing is repeatability. If you REALLY want to prove higher mileage, rent a couple weeks of dyno time in a lab. Control all the environmental variables to be constant for the whole week (temp, humidity, air flow, tire pressures). Empty the car 100% of all gasoline. put a predetermined mass of fuel in the car of a certain octane. Run about 40 tests and take the mean. IIRC 40 is the number where statistically each incremental test after that does not statistically significantly change the mean. Now change the octane and repeat all 40 tests.
Then and only then you can make assumptions if octane can change MPG.
so the higher octane combined with vvt-i will not change fuel econ?
I ALWAYS get better mpg with premium fuel than 87... the only peple that deny the fact are the ones that have not tried it
Black Yaris is offline
Old 06-25-2007, 07:40 PM   #2
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
Yes. Why would it?
WRBlue is offline
Old 06-25-2007, 08:00 PM   #3
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Yes. Why would it?
Wouldn't a higher octane allow the engine to increase its timing and make more power, which means that less fuel is needed to maintain a given speed?
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline
Old 06-25-2007, 08:47 PM   #4
Yarii
Drives: n/a
Engine's don't detect the octane of fuel... They just retard the timing if they detect knocking. Without doing some ECU tuning, the timing will always be set to or below (if knocking is present) whatever toyota engineers pre-programmed it to be based on engine and air conditions.
Premium might help keep the timing from retarding under high engine load like heavy acceleration or towing/hill climbing when knocking might occur, but for most daily driving, the engine will use the same timing settings it uses on regular gas.
Yarii is offline
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 09:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
