Old 06-25-2007, 11:23 PM   #1
Pars
Drives: 07 Yaris Liftback
Automatic transmissions tend to burn through the brake-pads more quickly when compared to a manual transmission. Reason being, driver's with standard transmissions can better utalize engine braking, while the Automatic is packed full of moving gears that will need braking force to bring them to a stop.
It's just a matter of time before the manufactors do-away with the mundane alternator and use hybrid technology to subsitute. This will give the engine one less thing to do, insted of using some of it's horses to run all the electrical stuff (like steering and gas pedal).
I've got 63,000km on my manual 5spd liftback and am still riding on the orginal brake pads. They're overdue for an inspection, but considering that they're not squeeling, I'm sure they're still fine.
Pars is offline   Reply With Quote
Old 06-26-2007, 01:00 AM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Mine do it sometimes also, but Pads should last well over 60,000 miles on this car.
Old 06-27-2007, 12:56 PM   #3
Pavel Olavich
Drives: 2007 Yaris LB
(1) Auto Trannies can also use engine braking, without any damage to the engine or tranny. Engine braking is not just for manuals.
(2) Our 2007 Yaris engine does not drive the steering pump.
Pavel Olavich is offline   Reply With Quote
Old 06-27-2007, 05:47 PM   #4
Edd
Drives: None
Very true, however, a clutch is a direct engagement, and when in good condition, transfers rotation 100% either way. A torque converter transfers close to that from the engine to the wheels, but only a small proportion for wheels to engine (20%?). Think about it, if it didn't do that, then in many situations the engine would stall.
Edd is offline   Reply With Quote
Old 06-27-2007, 10:04 PM   #5
Pars
I don't recall saying that Auto's don't utilize engine braking, nor did I say engine braking would cause damage. And, where does the electricity to run the electric steering come from? If it was a hybrid car, it might come from regenerative braking, which isn't the case for a regular car.
"Automatic transmissions tend to burn through the brake-pads more quickly when compared to a manual transmission. Reason being, driver's with standard transmissions can better utalize engine braking, while the Automatic is packed full of moving gears that will need braking force to bring them to a stop.
I've got 63,000km on my manual 5spd liftback and am still riding on the orginal brake pads. They're overdue for an inspection, but considering that they're not squeeling, I'm sure they're still fine."
brakes - how may km. Rabbit General Yaris / Vitz Discussion 9 05-28-2007 11:35 PM
Brakes and Shocks question jamal1984 DIY / Maintenance / Service 6 03-18-2007 04:26 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
Brakes jcove Performance Modifications 4 05-03-2006 11:59 AM
