Ok this is what I'm talking about could be false advertising but this is what I found: Toyota 2007 Yaris 1.5L Weapon-R Secret Weapon Intake System (305-157) The Weapon-R Secret Weapon Intake System was designed, to increase air intake volume to the engine. The concept is to create two different air velocity profiles, one traveling at higher speeds than the other does. This technology increases air volume and speed to the engine, which naturally feeds the engine 3x more air than the conventional air intake system. The intake pipe is bent out of high quality 6061 Aluminum on our Automated CNC mandrel bender. Polished to a high show quality finish. The SW1 Air filter features a tuned velocity stack to increase velocity and decrease turbulence.
Weapon-R Secret Weapon Air Intake Systems Weapon-R Secret Weapon Air Intake Systems How it works cut away illustration: (1) High Density Foam Filter (2) Turbo Velocity Stack (3) Primary Airflow (4) Secondary Airflow (5) Air Funsion (6) Hook Up for Optional Ram Air Hose Where the Dragon in take for 109 buck has the funky colors and that cage around the filter element. I'm telling you there is a difference or there wouldn't be that large of a price difference and separate names, I research the crap out of things before I buy them. |
| WR Secret Weapon Intake Dyno Tested.. | WRLEO | Performance Modifications | 70 | 05-17-2007 03:00 PM |
| Intake VS modified filter housing | Spades | Performance Modifications | 19 | 03-30-2007 12:30 AM |
| Reviews of Weapon*R Intake system.. | WRLEO | Performance Modifications | 6 | 02-20-2007 10:12 PM |
| Cold Air Intake vs. Short Ram Intake | nevermorez | Performance Modifications | 1 | 01-24-2007 04:25 PM |
