Old 06-28-2007, 11:26 AM   #1
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
The real reason an intake and header would be pointless is because with a turbo, the exhaust gasses and intake are re-routed.
Instead of the throttle body, the intake goes into the compressor housing. A new exhaust manifold is needed to attach to the exhaust housing. A new downpipe is needed to attach from the exhaust housing to the cat.
To buy for a future turbo build:
Low compression pistons
Rods
computer
clutch
Probally stronger axles
cams
Ofcourse any of that except the clutch will make you car slower N/A
WRBlue is offline   Reply With Quote
Old 06-30-2007, 02:08 AM   #2
armature
Drives: yaris lb
Rods
computer
clutch
cams
aside from the items in this list, i would add LSD, and gauges (oil temp, oil pressure, air/fuel ratio, boost gauge [useless until you're boosting but it's easier to do all the gauges at once]). also might want to upgrade the front brakes and wheels/tires. most important part about being faster is the ability to stop.
armature is offline   Reply With Quote
TURBO DIY... forpinks Forced Induction Forum 33 09-06-2007 02:03 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
NCP 91 RS 1500 TRD Turbo ????? ramishrrr General Yaris / Vitz Discussion 3 01-15-2007 04:51 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
