Old 06-29-2007, 05:12 PM   #1
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Originally Posted by fu_im_from_texas View Post
"....using a higher octane gasoline than your owner's manual recommends offers absolutely no benefit.
TRUE. As per Yaris manual, it recommends 87 or higher. Why "or higher" ? Ever wonder why Toyota recommends wasting your money ? With NO REASON ? Is Toyota in business with Shell ? Well, if not, there should be a reason, unless there are places on Earth that sell only 89 or higher octane gasoline... don't think so...
Engines are optimized to run with a precise level of octane. If an engine requires 87 and the owner put 89 or higher, there will be absolutely no benefit for the engine. On the other hand, if and engine is optimized to run with 89 and the owner uses 87, the engine will not run at 100% performance. It will knock more or little because the mixture ignites before the optimum moment during compression, thus leading to hot points on the piston/ring surface. Because the mixture ignites before the moment when the engine compression is optimal, it produces less overall performance. But not by much, one will not be able to feel any difference.
To resume... if using 87 the engine starts knocking, try changing the brand... the Yaris engine should not be knocking to an audible/damageable level while using good quality 87 octane gasoline.
hystria is offline
Old 08-15-2007, 01:47 PM   #2
Pavel Olavich
Drives: 2007 Yaris LB
The "or higher" phrase only means that if 87 is not available, then using a higher octane is not going to damage your engine.
Don't be so quick to read more into the words, then what is literally meant.
Also, to suggest as a remedy, to use higher octane than called for in the manual, a way to remove knocking is plain wrong. It would be far better to take the car in and determine why it is knocking at the required octane, and to remedy the problem. Going up in octane is a band-aide that only masks a real problem.
Pavel Olavich is offline
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 09:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
