Old 06-29-2007, 05:28 PM   #1
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
That didnt realy answer my main concern but thanks anyway.
Just wondering if it shows rmps consistantly....like an actual rpm gauge does...?? From stop to go, to stop again while driving~
I emailed the guy, but all he said was.....it tells you rpms of up to 9999.
I have a scanguage II and I usually have it on the rpm setting. You can have 4 settings on the screen at the same time obviously choose what you want (cause there's more than four). Anway the rpm one is digital so there is A LITTLE delay, but its relatively quick as far as showing the change of rpm and yes from start to stop or cruising, and since its digital its going to jump around a lot, but it works, if that makes sense. To be honest when I first got it I was a little disapointed in the rpm display but I'm still happy with it. I generally know what rpm certain speeds are. I have an auto so its not like I really need it but its fun to know. And no its not analog like a tach usually is, its digital. Hope that helps!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 06-30-2007, 05:21 AM   #2
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Thanks ECHOKnight2000, I really appreciate your response to that. I guess I wont mind a couple seconds of delay...just as long as I know about where in the clutch releasing it reaches a certain rpm before giving it gas.
