Old 06-30-2007, 10:13 PM   #1
critical
Drives: ewdew
Fiberglass will crack over time due to the stresse of the assembly. ABS is also harder to break in an accident where fiberglass will shatter.
ABS is in the plastic group , its surface is smooth and after painting it will be beautiful and do not have wavy effect as compare to painting a fiberglass surface
critical is offline   Reply With Quote
Old 06-30-2007, 11:35 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Where or what is ewd anyway?
Old 11-30-2008, 05:22 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That is simply not true. Well-fabricated fiberglass can be as good as (and sometimes better than) ABS for certain applications.
Fiberglass will only crack if there's an impact, or if it doesn't fit correctly and it's forced to be in a certain position. Fiberglass does not "shatter".
Fiberglass can be fixed/mended to look like new in case of an impact, whereas with any plastic (be it ABS or urethane) this is very difficult, if not impossible.
Also, the "wavy effect" that critical mentions can happen to any surface that is not completely smooth. That applies to ABS as well is it's not fabricated correctly.
2007 Yaris Unveiled at 2005 SEMA Show YarisBueller General Yaris / Vitz Discussion 0 01-12-2006 05:28 PM
