Old 06-30-2007, 05:40 PM   #1
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Angry Problems
So as it seems my rear axle on my Sedan is not centered on the car. I have not hit anything, nor curbed the car. I first noticed when I threw on my After market rims on, because they fill the wheel wells more. On the passenger side of the car the wheel is almost flush, and on the drivers side it is inset noticably more.
So hopefully when I take my car in it is covered under Warranty.
Has this happened to anyone else? I am at a loss right now. really annoys me.
Nick
nick1983 is offline   Reply With Quote
Old 06-30-2007, 07:35 PM   #2
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
That is bizzare! It should be under warranty I would think. Its a major part and I assumed you haven't messed with the axel. Did it look like this with the regular OEM tires on?
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 06-30-2007, 07:51 PM   #3
nick1983
nick1983's Avatar
Thing is you only really notice its out when the aftermarket rims are on, They are wider than stock. Stock are inset more so it is not so noticeable.
Old 06-30-2007, 08:42 PM   #4
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
I think someone else had the same problem. I just remember bits and pieces of the post but he had rubbing on just one side. He was on a trip with the family and gear to CapeCod I believe. It's probably in this tire forum. I'll check it out. Maybe it's a problem or maybe it's normal. Who knows......could be offset to facilitate other parts. Fuel tank, exhaust....
Chuck
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 06-30-2007, 08:45 PM   #5
Meteorite Man
Found it....WEIRD RUBBING PROBLEM
So i took the wife and the kid to Cape Cod this weekend, and trough out the trip my rear passenger side tire was rubbing the hell out of the fender. I freaked out and decided maybe it was a alignement problem and after taking the car to a local shop i saw what the problem was. The separation between the left strut and the rear strut from the body is different. The wheel thats rubbing has about 0.8 inch separation from the body compared to the side that does not rub. I have Rota Slip with 38 offset and 205/50r16 tires and NF's. Any ideas will be appreciated
Look in this forum under Weird Rubbing Problem
Hope it helps....
Chuck
Chuck
Old 06-30-2007, 11:22 PM   #6
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
just today i noticed what appears to be my passengers side rear wheel off a bit, top is out more then the bottom, level ground and the other side looks fine, but the car feels the same... going to get a better look tomorrow...
punch is offline   Reply With Quote
Old 07-01-2007, 04:16 AM   #7
nick1983
nick1983's Avatar
Thats what I thought about mine. Then I had a better look.
HELP WITH NEW 2007 PROBLEMS partenac General Yaris / Vitz Discussion 15 05-31-2007 06:06 PM
some minor problems after installing my HID kit, any professionals? ASHRAF DIY / Maintenance / Service 14 03-09-2007 11:54 AM
headlight problems KSIbucky DIY / Maintenance / Service 2 02-28-2007 11:54 PM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 12:50 PM
HELP tachometer problems!!! SamDaYarisMan In Car Entertainment + Electronics (audio / video / alarm) 16 09-08-2006 03:26 AM
