Old 07-03-2007, 01:47 AM   #1
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Originally Posted by seriousfun View Post
I just upgraded my system so I can play SA-CD, DVD-V/A (Dolby Digital and DTS), and CD/Radio/Aux (Dolby Pro Logic II) in surround.
Nice! You need a centre channel speaker next.
earljail is offline   Reply With Quote
Old 07-03-2007, 12:17 PM   #2
seriousfun
Drives: 2007 Yaris Liftback Black
But where in a Yaris LB?
Is there room under the dash for a 6.5" mid, with the tweeter mounted right above the guages? Should I get the Alpine SBS-05DC that fits under the Sony head unit (it won't match the timbre, frequency response, or dynamic response of the MBQs)? The Eclipe unit that clips to the back of the rear view mirror (I can't imagine it would sound great)?
I work in audio, I've been designing surround systems for twenty years, including music and post-production, and I know where the compromises are in my current car system. The Sony has a Center Speaker Organizer mode that makes a phantom center channel by mixing the Center content in the Right and Left speakers and uses some sort of voodoo DSP to steer that image so it favors the driver's seating position or others. So far, it sounds pretty good, but again, I haven't finished calibrating the system yet.
seriousfun is offline   Reply With Quote
Old 07-03-2007, 01:18 PM   #3
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
How about just in front of the speedometer. A surface mount tweeter or a shallow mid/tweeter. It will point straight up, but it could use the speedo clear plastic cover to reflect. Maybe even on top of the center display facing the windshield for reflection.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 07-03-2007, 01:53 PM   #4
earljail
earljail's Avatar
Yeah, you could fit a 3.5" or 4" coax there. There is at least 2" of clearance under that panel. If you could angle it a bit that would be perfect. Or you could do what I did:
Yaris Squealing Sound Yaris General Yaris / Vitz Discussion 19 01-18-2010 10:58 PM
