Old 07-03-2007, 02:42 PM   #1
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Not really. Though it's advised. I've decided to wait to install my springs until I get new shocks. You can ride on shorter springs but it will greatly reduce your shocks life span. :) So I've heard.
Old 07-03-2007, 02:59 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Tanabe stuff was tuned to work with stock. They will be fine and will last a very long time. If you want a truly sportier ride you would want to replace you struts or get coilovers. In my opinion.
SPONSORED BY
Old 07-05-2007, 08:15 PM   #3
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
How I approach this is simple. Shocks take typically probably 40,000 miles/60,000kms to expire. I wouldn't want to wait that long to enjoy my car with lowered springs I like the way it handles and the way it looks. Ok, so I'm impatient......
Lowering springs reputedly reduce shock lifespan and there are sound reasons why this is so, but it has been much exaggerated. If you simply cut your springs, yes, this would be the case, because you'll start bottoming out and riding on your bump stops too much, eventually breaking it. But with a proper set of lowering springs, the spring rate is increased to compensate for the reduced shock travel, and avoid bottoming.
So I figured I'd do the springs first, while waiting for Koni to roll out their replacement shock inserts for the Yaris. I hope that by the time the factory shockies start feeling tired it would be the right time to complete the suspension upgrade with adjustable Koni inserts.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
New Yaris ! Yarisagos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-04-2007 11:35 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
Shocks and springs Q grimez Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-19-2006 08:48 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
