![]() Drives: yaris 3 dr hatch Join Date: Oct 2006
Good job Bailout.
As I suspected, your commute doesn't involve much traffic. A major contributor to your awsome FE must surely be the fact that there are rarely any cars directly in front of you - this allows for coasting, FAS, etc. I probably see more cars in the first 10 minutes (5Km) of my hour commute (40Km) than you see all day. Put another way, most of us living in large metropolitan areas just can't achieve numbers anywhere close to yours simply due to the stop-go-stop-go traffic. I have tried to drive like an old lady, pumped up my tires, avoided using the A/C, coasted in neutral wherever possible, don't "warm up" the car in the morning, use synthetic oil (Mobil 1), use a block heater in winter, etc., etc., etc., and the best I have been able to achieve is 6.2L/100Km (38MPG). I don't get it The only things left to try: a. lose 100 of my 180lbs. and/orb. ask a few thousand commuters to stay home 7-8am and 4-5pm
Novice Hypermiler
Congrats man, however, I would suggest a different water bottle. You can get pretty sick by reusing the same water bottle over and over again even washing it. I picked up a Nalgene bottle for piece of mind.
#3 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Let's also not forget that I'm climbing huge grades every day. Yes, I get to use DFCO and FAS on the downhill sides but I have to climb both sides to begin with. In other words I am in far from optimal conditions. As a matter of fact, when I get to spend even just a little time on the valley floor my MPG generally boosts by 2 MPG for the tank. This means that if I weren't hill climbing every day I'd likely be above 55 MPG. You can hypermile in any scenario. :)
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 09:18 PM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
